Question about KLH DVD8350 DVD Player
KLH DVD 221
Hi Benimur:
I am having trouble installing my KLH DVD 221 player. We moved so I missplaced the connection cord can you assist on what it looks like?
and any help on how to install would be great help
Thank you so much for your help.
Amy
P.S. Nice bike
  • Anonymous Mar 18, 2014
    IR receiver problem.
    Brigadier General:
  • 6,966 Answers
My sincerest apologies. I was not made aware that you posted a direct request for assistance. It was only by chance that I saw your post.
To your concern should you still require information; most units would have a yellow, red and white connectors commonly called RCA. What is required then is a triple RCA to RCA connector as shown below. The yellow is normally connected to the video, while the red & white are for the R & L of the audio. An identical set would be on the rear of the TV unit henceforth the connection would be OUT from the KLH DVD 221 to the IN of the TV.
In some instances, a single cable is used to connect some models to the TV. This is called an RF patch cord and would look sonething like below. This would come form the RF OUT of the player to the RF/CABLE/ANT IN of the TV. Pls make sure that the style/form fits your units.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
SOURCE:
What size is the fuse to the power cord
Hi, you must check the user guide to find fuse rating or check the blowed fuse for current rating, for a DVD/Bluray player it could be about 2A /120V AC..
Jul 08, 2015 | KLH Televison & Video
Need manual for aklh dvd221
try to download manual on www.retrevo.com.
Jan 10, 2012 | KLH DVD-221 DVD Player
My sound doesn't work with the DVD fuction. It works on the Tuner, the VHS1 but not DVD. Do I need to connect the S-Video cable or what else should I try?
S-video would be a better choice than (yellow) composite video but it won't help the sound.
Not knowing anything about the DVD player and how you have it wired we can only guess what is wrong with IT or the connection to the KLH.
Have you looked at the manuals for the DVD and the KLH? You don't just hook it up and run with it. Digital Audio must be assigned, for example, and other stuff.
Apr 25, 2011 | KLH R5100 Receiver
How do you shut off the closed caption feature?
I do not know this dvd player, but on most anything with closed caption, you hit the cc button on the remote until you come to '0' or 'off'. As CC has about 6 channels it can use, but really only channel '1' is used. So you might have to cycle through the CC channels until closed caption disappears. Hope this helps. You might also have a setup menu on this DVD where you can control the CC.
Just cycle though it till you get to '0' or off, exit the setup menu.
Jan 07, 2011 | KLH DVD-221 DVD Player
DVD is stuck in JVC Player. Tray will not open.
I'm not familiar with the above, but many players have an openning unthernith so you can insert a screwdriver and slide the drower opend.
sorry about the grama.
Jun 11, 2010 | KLH DVD-221 DVD Player
Recording from VHS to DVD
Appreciate the direct "Ask Me".
To my knowledge, a KLH DVD8350 is only a player, it has no recording capabilities, sorry.
Nov 08, 2008 | KLH DVD8350 DVD Player
Ac adaptor cord
you can get a power cord for the Durabrand pdv705 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Oct 12, 2007 | Durabrand PDV-705 Portable DVD Player
TROUBLE WITH KLH DVD-8350 PLAYER
need more info, but did you try with another movie dvd? have you clean it with a cleaner dvd, blow some dry air by the port of the tray when it is open(could by a can in radio shack), if everything dosent funcion, then, you need a tech, the disc is not runing or the reading sistem has damage...good luck
Aug 08, 2006 | KLH DVD8350 DVD Player
KLH DVD8350 DVD Player Logo
93 people viewed this question
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
