Karcher DE4002 Steam Vacuum Logo
Posted on Jun 15, 2011
Is there a reset button on the karcher de 4002
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
531
Points
Open the lid and you will fine a red button with a clear rubber cover
press that button. When you have to reset, it is telling you that you need to descale the unit
When turned on blowing fuses
Short circuit inside machine. In a device typically resulting from the unintended contact of components and consequent accidental diversion of the current.
2helpful
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
2answers
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
1helpful
Karcher sc 952 having problems with no steam coming out.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
4helpful
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
5helpful
2answers
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Karcher k2.94
there was a techinal update on this machine a few months ago, the oil may be leaking from the swash plate housing
Top Karcher Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
