Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore side by side
Refrigerator side is not cooling and i think freezer is not as cold as it should be either. I poled the unit out and looked in back. A small black tank (which i think is condensor is very hot) could this be my problem.
  • 126 Answers
FIRSTLY THE CONDENSOR DOES GET HOT TO A CERTAIN DEGREE THAT IS NORMAL.HAVE YOU NOTICED IF THE CONDENSOR IS BLOCKED WITH DIRT.IF THE UNIT IS FITTED WITH A COOLING FAN NEXT TO THE COMPRESSOR (MOTOR) MAKE SURE THAT IT IS FUNCTIONING WELL.YOUR LAST RESORT COULD BE THAT THE INTERNAL FAN MOTOR OR SENSORS ARE NOT WORKING CORRECTLY.GOOD LUCK
Posted on Sep 10, 2008
Can refrigerator work if freezer is not in a kemore side by side?
Unfortunately, no. If your freezer is not cooling then your refrigerator side will also get warm. The freezer is the source of cooling and it uses a fan to force the cold air into the refrigerator side. I would suggest calling a repairman to look at it for you to find out if it is fixable. It could just be something simple and does not always mean that you have to replace the unit, but that may be a possibility as well. Sorry!
Dec 04, 2013 | Kenmore 50522 / 50524 Side by Side...
Bottom of freezer side gathers water which eventually freezes. We think its coming from the ice maker
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Kenmore 57706 Side by Side Refrigerator
Freezer working fine-refrigerator not cooling-unit bought 1998
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
tydue6
Oct 17, 2009 | Kenmore 50522 / 50524 Side by Side...
No cooling in freezer or fridge. Still running with lights on and air coming into freezer from vent inside freezer at the back but not cold air.  Kenmore Side by Side circa 2001 with ice and filtered...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Apr 26, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore cold spot not cooling properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
jsrha
Apr 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
New Refrigerator Past Warantee Not staying cold
It sounds like your condenser coils need to be swapped.
Replacement parts are available from the manufacturer and aftermarket suppliers. More conveniently, you may be able to find replacement parts through the retailer that sold you the refrigerator or at an appliance parts store.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Refrigerators
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
