Question about Minolta Office Equipment & Supplies
Forgot to reconnect heater when switching on, now have error code C05. I do not know reset code.
PROBLEM SOLVED
MINOLTA EP 1085 COPIER, RESET BUTTON ON MAIN BOARD.
THANK YOU
Posted on Aug 21, 2008
Minolta EP 2030 error code C05 how to reset
open the front door with power on in the upper left you should see a small panel remove the cover, press the small switch wait for ready to copy, if the code comes back do not reset the FUSER is bad it can start a FIRE ruining a perfectly good day!!!!!
May 10, 2017 | Minolta Office Equipment & Supplies
Error C05 Konica Minolta Dialta D152 can y repair?
To reset turn ON the power switch with the Stop key held down.
Mar 21, 2013 | Minolta Di152 Laser Printer
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
MY KONICA 7115 COPIER HAD DISPLAYED ERROR C05 00 CAN YOU HELP ME
turn off the machine and hold down the STOP botton while turning on the power .hold for 5 seconds .
than should reset the code .if the code pressist that you have a bad thermester in the fusing unit.
good luck
May 01, 2010 | Xerox CopyCentre C118 Copier
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
C05
Sir to fix will require you to take the rear panel off with the copier on. the upper rear panel once you have it off. Then find the circuit board on it will be a small black button, lower right side. press it. the machine will reset if it comes back your fusing unit (The HOT) part has a bad lamp thermistor, or thermosat. And will need replacing. The code will not clear by powering off then on. or by opening and closing front door.
Mar 10, 2010 | Minolta EP1083 CS/PRO Copier
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Oct 13, 2007 | Office Equipment & Supplies
Minolta CSPRO EP2030
You Can make reset for this code by: 1. Open the front door of the machine & lift the upper half 2. Turn the machine on 3. Locate the srvice switch on the main board( backside of the machine you can reach even without opening the back cover) 4. If this code is coming from time to time just change the upper heater roller
Oct 05, 2007 | Office Equipment & Supplies
140 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
