Question about Microwave Ovens
Maytag microwave light bulb MMV5207BA/BC
This is the most unfriendly consumer problem I can remember ever dealing with. In order to change the Maytag microwave light bulb you need to practically disassemble the unit reach inside (small hands are needed) and when you replace the Maytag bulb with a standard 20 watt appliance bulb as the manual says, you discover that a standard bulb does not fit...it's too short and you can't get the replacement just anywhere...can you suggest where one can get Maytags "special" bulbs?
...now I feel just a little better.
  • grannymade Aug 21, 2008
    ...the difference between the bulbs are in the length of the pins.The Maytag bulb's pins are about 1/8th" longer than a standard 20watt pin appliance bulb like a Sunlite halogen #Q20Bipin.
    Pins are shorter so bulb don't stay in...light not work...it almost seems intentional, and for sure an unnecessary annoyance.
  • cheekee Nov 28, 2008
    bulbs from Home Depot won't stay in, and if you manage to get it to stay in, only lasts about 1 week ..... also, can only find 35W version of these bulbs....
A 20W, 120V replacement xenon halogen bulb with G8 base can be purchased from Lowe's.
Posted on Apr 21, 2009
  • IamDexter Jan 03, 2011
    Found out the part number for the bulb: 4713?001165 - Lamp, Halogen
    I guess this was no longer manufactured so the most recent part is now called:
    WPL-4713-001165 (which is manufactured by Samsung and I found it pretty cheap at this site:
    http://bit.ly/fDyLKN
  • Microwave Ovens Master
  • 9,098 Answers
Neither the service manual nor the parts list refer to any bulbs, so they must be standard types.
This should be a standard 20W "appliance bulb" available at grocery stores, home improvement centers (Lowe's, Home Depot, etc.), hardware stores, and places like Wal-Mart...
Are there any numbers on the bulb you can share with us?
Do they look like these?
Posted on Aug 21, 2008
  • William Miller
    William Miller Aug 21, 2008
    Can you post a picture of the lamp you took out of the oven?
    Now you're talking about a halogen?
  • phnortel Oct 01, 2010
    You need to be an electrician or mechanic to get to the light bulb in this microwave. Then good luck in trying to find a replacement. Yuck they don't tell you this before you buy.
    morrie
The problem I had is that the base of the bulb was too wide for the socket. I ground down the glass edges of the bulb base and it slid right in. It did not take much, but, I had to grind down both sides. I used a diamond rasp bit in my Dremel medium speed.
My first thought was to grind down the receptica edges, but, the bulb is less expensive to replace.
Posted on Oct 15, 2011
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How to change the hood light
By hood light I assume that the light you want to replace shines from the bottom of the unit, not the light inside the microwave. If so check out he Disassembly video on this site: Maytag Microwave Light Bulb Not Working
Jan 02, 2015 | Maytag MMV5207BAW Microwave Oven
Why if you put in a new light bulb the light bulb does not go on
It is because the light bulb may not be the problem to begin with. You should check the light bulb socket and related wiring and connectors for any cold solder joints.
If you have a multimeter you can check to see if there is any AC voltage going to the socket. If you don't know whast your doing then I would suggest you get someone that does. Remember your dealing with 120 volts.
good luck
Apr 07, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Jvm1440I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
Blew a trace off of the back of the board by it shorting out when the bulb was unscrewed, Either have to find someone to repair the main circuit board or order a new one. But $$$$ always unplug the Microwave to replace the builbs, It doesnt seem like a big deal but I have seen this a lot over the years and it really does some damage to the main PC board.
Oct 06, 2017 | Microwave Ovens
INTERNAL LIGHT DOES NOT COME ON WHEN MICROWAVE IS OPENED OR WHEN RUNNING. I AM NOT SURE WHICH REPLACEMENT BULB TO ORDER
the bulb can be taken out from inside the oven just open the boor and look inside for a grill behind this is a light bulb, sorted easy
Oct 20, 2009 | Maytag MMV5207 Microwave Oven
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Over the Range Light Bulb
"Appliance Parts Pro's" web-site bet they will have it or can get you the exact thing you need
Jul 18, 2009 | Maytag MMV4205 Microwave Oven
Where does the light (lamp) in a Kenwood SJ SS 25 microwave go? I ordered a bulb but am unsure of how to put it in when it arrives. The booklet that came with the microwave says "don't do it...
I did not fix the problem. I ordered a bulb (lamp) and subsequently saw it is beyond my knowledge to install it. I'll communicate with the store where I bought it 3 months ago and if they won't deal with it, I'll pay a repairman to do it.
Aug 20, 2008 | Microwave Ovens
Microwave Ovens Logo
4,133 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
