Question about HP Photosmart C4280 Aio Printer
Reinstall software each time the printer is reconnected
The printer is connected to a Toshiba A55-S326 laptop running XP Home edition.
Almost daily, the printer is disconnected from the laptop because the laptop is used in other places. My problem is when I return and reconnect the printer, the printer will not work until I reinstall it. This is time consuming, the install disk has to be placed back into the cd and I have to wait until everything is finally reinstalled. I have copied the disk to the hard drive but I still have to direct the program to that folder. The printer that was installed previously will not work so I have to reinstall. After the re-installation, if I check the printer and fax folder the printer will be installed as a copy of the previous printer. At one time this printer was listed 8 times. What can be done so that when I reconnect the printer I won't have to reinstall the software each time?
Completed registration steps, did not solve problem.
Rebooted computer after install,
Used same USB port.
Searched for updated drivers
None of these solved the problem.
  • ed29010 Aug 20, 2008
    Tried that, didn't work. thanks
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm...maybe the way to do this is to use the remove hardware icon in control panel, instead of simply disconnecting the printer from the laptop.
also, go to www.hp.com and get the newest drivers, which are almost certainly more recent vintage than those on the cd.
Posted on Aug 20, 2008
SOURCE:
My toshiba laptop satellite A55-S326 wont boot. Only can use the escape key then go into bios but still doesn't boot. Tried my recovery disc & it goes thru the instal but then still goes to a blank...
Your install discs are bad. Please don't shoot the messenger. Call Toshiba for new discs. Here is the number (it took me 30 minutes to find this. Please give me a 4-thumbs-up rating. If you don't, I spent time away from family for free).
(800) 457-7777 (toll-free)
Sep 24, 2011 | Toshiba Satellite A55-S326 Notebook
I can't boot my CD XP,boot to other devices too.. can u help me?
You can select an alternate boot device by pressing F10 or F12 as the Toshiba is booting up. You will get a list of boot devices, move the left or right arrow to select the device you want to boot.
OR
Go into the BIOS configuration and change the boot order of the devices your want to boot up with.
Apr 06, 2011 | Toshiba Satellite A55-S326 Notebook
My toshiba sattellite a55-s326 has a flashing yellow light but won't power up.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Hope this works
Mar 16, 2011 | Toshiba Satellite A55-S326 Notebook
Support updates does not list my Satellite A55-5326 on there sight. My light is flashing and will not power up.
how many times? 1, 2,3....
maybe battery dead or hardware problems, you can tell-me how many times flash and is a code with 3 digits, like morse
Aug 08, 2010 | Toshiba Satellite A55-S326 Notebook
Did a restore to my A55-S326 with factory restore CD. Now I have no sound.
The drivers all all here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=713844&rpn=PSA50U&modelFilter=A55-S326&selCategory=3&selFamily=1073768663
In the catorgory dropdown choose sound
Also check you device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc Make sure you do not need other drivers
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 26, 2010 | Toshiba Satellite A55-S106 PC Notebook
Toshiba won't start
Hi, what happens when you push the button? Lights, sounds from inside the laptop, anything flash on the screen?
Sep 27, 2007 | Computers & Internet
HP Photosmart C4280 Aio Printer Logo
43 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
