Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Dell Monitor 2007 WFP
My monitor keeps going into power save mode. I thought maybe overheating had something to do with it but this morning when I turned it on it happened within few minutes of turning it on. I cleaned off the dust inside the computer and I'll probably switch to VGA from DVI to see if the plug is the issue. IF anyone has experienced this or has any suggestions please do tell. I've searched for answers through different forums and this question often seems to be left hanging?? Any advice from any experts would be greatly appreciated! Thanks
  • rootytootie Aug 20, 2008
    :( I'm not a technician but thanks for the info.
  • genp Sep 25, 2008
    Dell 2007wfp entering power save during ingame (Savage2, Assasin Creed,Crisys any other *graphical* game, but not TeamFortress2,Psyconauts or RavingRabbids2 for example)
    OS: Vista x64
    Videocard: ATI X1950 PRO 256mb (Sapphire)
    Motherboard: Asus P5B-E
    CPU: CoreDuo (overclocked slightly)
    Genius:
  • LG Master
  • 1,550 Answers
If you are a technician you can repair it,because the problem maybe are a cracked solder joints on the feed mainboard and you need to resoldered all.Good luck
Posted on Aug 20, 2008
Have a Dell E228WFP monitor keeps going into power save mode.
does it go into power save mode with your actually doing something. Like for instance if your typing does it go into power save mode? If its going into power save mode when your not doing anything on it then its as simple as a setting either on the monitor itself or in the power settings within your computer accessible by the control panel and screensaver
Jul 22, 2012 | Dell E228WFP LCD Monitor
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
"Power Saving Mode" problem
To solve your problem please remove RAM and then insert it again. It will resolve your issue. All the best
Jul 27, 2010 | Dell ST2210 21" Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Dell monitor enters power save
try to reconnect the cables to ensure it's properly plugged in (if you have another monitor, you can try it to ensure that your system is running properly) If you narrow it down to a monitor problem, it's most likely the inverter/power supply board in the monitor. If it's covered under warranty, you can send it back to Dell and they should send you a refurbed unit. If not, the board can be as expensive as finding a decent used monitor on ebay that works.
May 02, 2009 | Dell E193FP 19" LCD Monitor
MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
Dec 29, 2008 | Dell SE198WFP LCD Monitor
No composite input signal
`Hi,
If the monitor is making the noise , the monitor circuit baord has gone bad.
If you have purchased the monitor on a seprate order from dell it would be covered under 3 yr warranty. If the same has been bought with the Dell computer , it would hold the computer warranty. would request you call the manufacturer.
Before you call Dell , you can try the following things
1. Disconnect call cables from the back of the montior
2. Press the power button a couple of times in the front of the monitor to drain any resident charge
3. Reconnect the power cable
4. check if you see the monitor self test running and if the noise is still there with there
Thanks
Proton
Oct 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
Apr 25, 2008 | Dell E173FP 17" LCD Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
193 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
