Intel Pentium Dual Core E2140 / 1.6 GHz processor (BX80557E2140) Logo
Posted on Jun 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ddd - Intel Pentium Dual Core E2140 / 1.6 GHz processor (BX80557E2140)
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jun 15, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557522
Points
31058
> ddd
D-D-D-DUM -- the first 4 notes in Beethoven's "Fifth Symphony".
How to log on to D-Link dgs-2208_ds
On your computer, enter the 'IPCONFIG' command.
Find the IP-address for the "gateway".
Start Internet Explorer, and enter 'http://aaa.bbb.ccc.ddd
where 'aaa.bbb.ccc.ddd' is the IP-address of that "gateway".
Login with ID/password of the router.
Decoder muitichoice d5d 990 flashes ddd does not respond to remote shows no pictures on television
1) replace old batteries put a new ones, but you must clean and tight the spring contacts batteries from dirty, corrosion, oxide, use contacts cleaner.
2) opent the r.control and clean the keypads from dirty, oxide,corrosion, with c. c. and try again. the LED must be ON when you hit any key. use the digital or cell phone for to view. see the diagram attached.
Mfg date
Every Dell part has a label with a long serial number in the following format:
CC-PPPPPP-MMMM-DDD-SSSS
CC= 2 letters, country of origen (e,g, TH for Thailand, CN for China).
PPPPPP= 6 alphanumeric, Dell internal part number, most times starts with 0.
MMMMM= 5 numbers, Vendor ID.
DDD= Manufacturing date code
first digit= number, manufacturing year (e.g 8=2008, but on old stuff could be 1998)
second digit= alphanumeric, manufacturing month (1=January, 9=September, A=October, C=December)
Third digit= alphanumeric, manufacturing day of the month (1=1, 9=9, A=10, B=11,....and so on).
SSSS= 4 alphanumeric, serial number.
Not sure what date code you are looking at unless a "Plain Language Request" was made for that series in which case it would have been manufacturered 2020 - February (02) - 19th. Not a lot of these and I have never seen them on Dell but I guess anyting is possible
Make a nocking noise from the engin
What kind of noise. First of all is your oil full? Is it a tapping noise, or a thud from below. Does it squeal? you need to be more specific.
I'm looking to get the pre-set patterns to play on my Korg DDD-5
A demo on YouTube shows the owner pressing one of the buttons on the left side to select possibly a bank as well as the start.. I could NOT find a manual online to download.
Jan 09, 2010 • Korg Ma30
Ght
2543wert4656644564w564545 6rfte ttt ttt dd dd ttt ddd ttt ddd
Low lan connectivity or limited lan connectivity
Hello Sir,
all computers on the same physical subnet need to have ip addresses in common
meaning the first three numbers in aaa.bbb.ccc.ddd are the same and are different only in the ddd portion.
In addition, the subnet mask must be alike or ensure that some ip addresses are not excluded
Typical subnet mask is 255.255.255.0 or sometime 255.255.254.0
Usually, there's a gatway address; a target which is used to send packets out
of this machine and hopefully towards the other machine.
For all machines, use the Run->cmd and enteripconfig /allYou should have similar results on all machines, so look for major differences eg: gateway on one is 0.0.0.0 or not shown while other have non-zeros,
or ip address on one start 169.254 another starts with 192.168
The 169.254.y.z addresses are pecuilar
ms article comments on auto-config:
example : IP-address assigned via Auto-IP-Configuration :
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Autoconfiguration IP Address.. . . : 169.254.4.69
Subnet Mask . . . . . . . . . . . . . .: 255.255.0.0
Default Gateway . . . . . . . . . . . . :
Thanks
Cheers!!!!!!
Good luck
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
