Have put a lg dvd/rw into my computer , have plugged in to my asus a7v880 motherboard in the sata1 connector but i cannot talk to the drive or get windows xp to find it
  • 1 more comment
  • paceman Aug 20, 2008
    all i can find on the lg site are firmware updates. if these are the files i need can you tell me how you install them
    there are no jumpers and the cables are fine
    there is nowhere in the bios to set them
  • 1,879 Answers
Try using any available SATA connection / try it on another computer.
Posted on Aug 20, 2008
    Sergeant:
    Champion:
  • 298 Answers
You need to enable sata in the bios and then restart. Then go to asus and type in your motherboard model number and find the driver for video components and get the driver for the dvd player
    Champion:
  • 208 Answers
The Machine: drivers issue in normal mode? you mean upper lower filters issue.
    Scholar:
  • 133 Answers
U have to go with a professinol repairer
    Master:
  • 763 Answers
Try to configure it on the cmos(from the start of your computer to run) and try to detect it on the settings by removing and inserting even if its turn on. i usually doing it whenever i got problems with sata's and ide's. hope that helps!
CHARCOIS
  • 6,487 Answers
What you need to do here is to make sure that your DVD/RW is connected properly on to your motherboard , because that firmware is useless because you cannot update it since your computer is not detecting it..
Hope that helps..........
  • Mark Gil
    Mark Gil Aug 20, 2008
    if that's the case this DVD/RW can be bad that's why its not even detected by your computer and there's no way you can update the firmware of it if its not detected...better have it replace.
    Master:
  • 638 Answers
Its not the problem of installation its the problem of detection.just enable the sata ports in the bios ,then save the settings, then restart the pc and windows will detect the device.very simple.do it.thanks
  • 813 Answers
Chak the master / salve jumper or chk the cable mighet be loose
    Master:
  • 788 Answers
That SATA connector is probably disabled in the BIOS. Press [Del] when your computer boots to go into setup. Poke around there should be an option, most likely on the advanced page, to turn off certain SATA ports. Make sure they are all enabled then pres F10 to save and exit. Reboot windows and hopefully it will find the drive.
Otherwise your SATA controller drivers may not be installed or working. Download the newest chipset and IDE drivers from Asus or VIA.
  • Dean Joly
    Dean Joly Aug 20, 2008
    FYI
    Ronnieh49: Optical drives do not need drivers, the controller they plug into need them.
    Ginko: SATA drives don't use slave/master jumpers.
  • Dean Joly
    Have you checked your BIOS setup?
    It could also help to check your system in Safe Mode to see if the drive is detected there, you need to press F8 after the ASUS POST screen but before Windows starts. If it is then there may be a driver issue that is causing it to be invisible to Windows in normal mode.
    Genius:
  • 2,920 Answers
You will need to go to the website that makes the drive and download the drivers for the dvd
  • 19,396 Answers
Check the slave / master jumper settings, they meay be clashing in bios.
Try plugging to the other SATA port.
  • Ginko
    Ginko Aug 20, 2008
    Sata disk drives do not require any driver, check instead the solution proposed by the Machine.
    If sata channel was disabled from bios, reward the machine by accepting his solution.
    Do not forget to save changes after modifying bios values.
    regards.
Cant find my motherboard pin out
http://www.pcmag.com/article2/0,2817,2388344,00.asp?tab=Specs
With all due respect, you have the manual in front of you now
That is unless you started unplugging wires already, and didn't make notes, drawings, or take photos.
Let's use the Asus Essentio CM1630 motherboard for an example.
Couldn't find a CM1730, but that's OK. We'll use this one for a general example,
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CM1630-MOTHERBOARD-61-MIBBJ5-01-TESTED-/181007679725?pt=Motherboards&hash=item2a24e600ed
Put your mouse cursor in the middle. Now move your mouse around, using the Zoom In feature.
If this motherboard were mounted in a computer case, it would be turned 90 degrees to the Right.
Bear that in mind.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Goes by many abbreviated names.
PNL 1, FP1, PANEL1, etc.
(Panel 1, Front Panel 1, Panel 1)
Go to the Top/Right corner of the motherboard photo. To the 6 Blue SATA connectors.
Immediately to the bottom of them, is a white Front Panel header.
Two rows of contact pins sticking up.
You need to make notes, drawings, photo, whatever; of where the wires from the Front Panel, go to each one of those pins.
(Some may not be used)
How to know which wires coming from the Front Panel, are the Power On switch wires, Power On LED light wires, HarDDrive activity LED light wires?
Remove the Front Panel from the computer. If it is Not just a cover, EASE it off just enough to look behind it.
You usually can follow the Harddrive activity LED wires.
Harddrive activity LED is usually AWAY from the Power On switch, and Power On LED light.
There's two wires down.
Now look at where the Power On LED light is. Can you see wires going straight to it?
Two more wires down.
From process of elimination, you now know the last two wires going to the Front Panel, are for the Power On switch.
(The Power On switch, is part of the plastic Power On Button assembly. If you look close at the Power On Button assembly, you can see this)
THAT sir, is the MAIN thing.
I can guide you where the other cables go, as far as power cables, and Harddrive cables, and Optical Drive cables. (CD/DVD drive)
If you have already disconnected the Front Panel wires to Front Panel header on motherboard; you get to play a game(?)
Power Supply plugged into power, use a small flat tipped screwdriver, and touch two pins at a time.
When you get to the two Power On switch wire pins, the Power Supply will come on.
Now it is a process of elimination.
Use an LED with two wires, to find out what the rest of the pins are.
The rest of the contact pins in the Front Panel header.
Grab the HDD LED light, or Power On LED light.
You're getting a new computer case anyway.
Touch two pins, and the LED light blinks?
That's the HarDDrive activity LED light, pins.
LED stays on?
That's the Power On LED light, pins.
Either of those LED's are dim, (When the Harddrive is active, or when the computer is on), switch the wires around.
You have the Positive ( + ) wire mixed up with the Ground ( - ) wire.
Moving on.............
The 6 Blue SATA connectors on the motherboard:
If you look close you will see;
SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5.
Or it may be,
SATA1, SATA2, SATA3, SATA4, SATA5, and SATA6.
The Harddrive plugs into SATA0 or SATA1.
Just depends on what the SATA connector numbering starts with.
The main optical drive, or a single optical drive; plugs into SATA1, or SATA2.
A secondary SATA optical drive will plug into SATA2 or SATA3.
(Look at the SATA numbering above, and you can compare side, by side )
HOWEVER, the beauty of SATA is; that you can plug whatever you want to, in ANY SATA connector on the motherboard; and BIOS will find it.
Plug the Harddrive into SATA 3? No problem.
Plug the optical drive into SATA 0? No problem.
BIOS will find the drive with the Operating System on it.
The Harddrive.
Then BIOS will know the other drive/s are optical drives.
(Make sure in the BIOS Setup utility, that the SATA connector on the motherboard you are using, is Enabled.
Otherwise BIOS will Not see the drive)
What cable from the Harddrive, and optical drive; plugs into those SATA connectors on the motherboard?
A SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable connector.
Lines up with an L-shape on the motherboard connector.
One example of a SATA connector on the motherboard is shown.
This one is an Open design. Your SATA connectors on the motherboard, will be a Closed design.
Between a SATA data cable connector, and a SATA power cable connector, the SATA power cable connector is larger in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
See the SATA harddrive example?
Note the L-shape is pointing DOWN. It is this way EVERY time.
Now you know which way to turn the SATA data cable's connector, when installing. 'Foot' of L-shape goes Down.
More in a Comment.
Mar 14, 2013 | Computers & Internet
How to Replace the DVD RW on my PC /HP Pavillion a6130n /
Better
There is Me
HP Support > Pavilion a6130n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3436817&lc=en&cc=us&dlc=en&lang=en&cc=us
How to > Adding / Replacing hardware > Opening the PC Case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968217&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
Back page; Adding / Replacing hardware > Removing the Front Cover,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968624&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
Back page; Adding / Replacing hardware > Adding or Replacing a CD or DVD Drive,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00981303&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
This is an example of a SATA data cable,
Note the L-shape inside the cable's connector.
It also shows a SATA connector for the motherboard.
Note the L-shape on the connector. The optical drive (CD/DVD drive) also has this L-shape on it's connector.
(SATA connectors on the motherboard come in various colors. Color signifies what SATA connector it may be. SATA0, or SATA1, or SATA2, etc.)
Between a SATA data cable's connector, and a SATA power cable's connector, the SATA power cable connector is the larger of the two.
SATA data cable connector has 7-pins. (Contact pins)
SATA power cable has 15-pins. (Contact pins)
Example of a SATA power cable,
A SATA data cable connector, and a SATA power cable connector, may have a small 'bump' on them, that you depress with your thumb, when installing the cable, or removing. The 'bump' is a Lock.
Usually the cable end going to a harddrive, or an optical drive; will be a 90 degree Elbow.
The straight end connector plugs into the motherboard.
A Top View look at the motherboard in your computer,
HP Support main page > Product information > Product specifications > Motherboard specifications, MCP61PM-HM (Nettle2),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
View shown has NO hardware on the motherboard.
(Processor, Ram Memory, etc)
The long Blue, and Black slots, with the White Lock 'ears', are Ram Memory slots.
The SATA connectors on the motherboard, are to the bottom/right corner, of the Number 3 and Number 4 ram memory slots. (Blue)
Yellow, Blue, White, and Black.
Scroll down, and click on the + sign to the left of the blue -
Motherboard layout
Using this illustration you can see;
Yellow SATA connector is SATA4 <-
Blue SATA connector is SATA3
White SATA connector is SATA2
Black SATA connector is SATA1
Due to standards set by JEDEC, and generally followed by all; the harddrive is plugged into SATA1.
HOWEVER, you can plug your optical drive, or drives, or harddrive, or harddrives; into ANY SATA connector on the motherboard that you want to.
The beauty of SATA is that BIOS will find the drive, NO matter what SATA connector on the motherboard you plug into.
Harddrive, or optical drive.
For clarification on anything I have stated above, or for additional questions; please post in a Comment.
Regards,
joecoolvette
Nov 05, 2012 | HP Computers & Internet
A7v880 does not start
Reset your motherboard in doing this, you have to take off the cmos battery and put your jumping settings to clear cmos.And also try to check your video card cause sometimes it would be the reason.
Mar 14, 2012 | ASUS A7V880 Motherboard
Can I use a external audio card on matherboard ASUS a7v880? Is there a port on this motherboard for external audio card?
Yes, you can use one. Just plug it in a PCI slot; or of it's an USB one, in any of the USB ports of the motherboard.
Oct 25, 2010 | ASUS A7V880 Motherboard
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
PC shuts down on Asus P5sd2-vm with LG DVD Rw (GH22NS30)
If you are sure that it works with other DVD drives, then I cannot help.
But if a system shuts down suddenly, the first thing I would check would be the CPU temp. At around 97 degrees, Intel processors shutdown to protect from excessive heat. Go into the setup (some call it BIOS) and check cpu temp.
If that's not the problem, then you should consider things like drivers problems, virus infection, broken hardware, compatibility issues. Try to search technet site at microsoft for a similar problem.
Good Luck!
Tareef Attar, MCSE, CISSP, CISA
Dec 19, 2008 | Computers & Internet
Internal DVD Drive
if you,ve purchased a SATA drive.
Then you should have SATA Connectors On The Motherboard.
If you look carefully you should see SATA1 And SATA2 if applicable. they,ll look like a small black/white piece of plastic connector. shaped similar to a letter *L* this is the sata connector, you may already have a hard-drive on 1 of them. ( red Cable ) The 4 pin audio cable, goes from the rear of your DVD Drive, you should have 2. 1 for analogue 1 for digital. this connects Audio from your Drive to motherboard, slim grey cable ( usually ) look towards the rear of your motherboard for this, usually towards the audio out ( if you have onboard soundcard )
connect this to Audio/sound ( you,ll probably have 3 located close together.
Hope this helps.
Mike @ Compurepair.
Feb 11, 2008 | Computers & Internet
Where to connect what on motherboard
Very generic questions so lets see if i can answer as best as i can. hard drives and dvd are very similar principles (see below)
hard drives comes in SATA or PATA. If its a SATA then there should be small red connectors that you should plug the HD in on the motherboard while PATA or IDE drivers should have white connectors. They are wider in width of the cable containing about 24 pins. The motherboard would also call out SATA1,SATA2 etc so you know its the SATA plug. Likewise for IDE drives.
Regarding power switches, on most motherboards there should be a set of pins at one corner of the board with tiny little letters pwr next to it. You will need to connect power switch cable from the case to the motherboard.
I highly recommend you read the manual that comes with the motherboard to see where it is located.
good luck
smeags.
Jan 04, 2008 | Computers & Internet
Jumper
Does the cord going to your CD-RW hasve asnothe plug further down the line most computers can connect 2 cd type drives!!!
Jan 02, 2008 | Pioneer (dvr-a06u) DVD±RW Burner
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
