Question about InFocus LP 820 Multimedia Projector
Red Spot in the picture of my Infocus LP-820
I have a pixelated red spot that projects on my screen from my projector. It seems to change shapes (from about 75 pixels to only 4) and seems to get smaller the longer the projector has been running. Any Idea what is wrong with my projector and how it can be fixed?
    Genius:
  • 2,985 Answers
This would appear to be a componeent failing and I doubt if it is user fixable.
If it unser warranty send it back whence it came,
Further support try here
http://www.google.co.uk/url?q=http://www.infocus.com/support.aspx&sa=X&oi=smap&resnum=1&ct=result&cd=2&usg=AFQjCNFdFuwQfzBpULQpcHnzxmC_n12fdA
Posted on Aug 20, 2008
THere are an increasing number of white spots (damaged pixels?) on the projection screen. It started with one, and one flickering, now there are 4 clear spots, and another flickers. Can this be solved?
If the spots are well defined rectangular shapes, then DMD pixel failure would most likely be the problem.
You could replace the DMD chip, but it might be more economical to sell the unit as is and buy a new one
Jun 08, 2011 | InFocus IN1102 DLP Projector
My InFocus IN2102EP projector is recently projecting a small white spot. If it was a PC, I'd say that a pixel was out. I've try blowing compressed air in various places, and have removed and replaced the...
Sounds like the DMD chip is on it's way out.
Check if the intermittent problem is related to the external air temperature. Try blowing cold air around the unit with a personal fan to see if it does the same thing.
Check if the air vents and filter is clean
Apr 12, 2011 | InFocus IN2102EP Projector
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
I am getting a red spot on my screen. Is this a
no, it is the light filter (polarizer). it is caused by excessive heat and dust buildup. blow out projector with canned air to prevent further discoloration, but the filter needs replacing.
Aug 04, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Jan 29, 2009 | InFocus LP 850 Multimedia Projector
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Green spot
the light polarizer on one of the lcd panels is fried. bad news: you'll have to replace the entire optical engine. worse news: infocus no longer sells them. sorry.
Aug 22, 2007 | InFocus LP 735 Multimedia Projector
InFocus LP 820 Multimedia Projector Logo
309 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
