Question about Lexmark Office Equipment & Supplies
Laptop cannot install prog from printer s/ware?
    An expert who has answered 500 questions.
  • 564 Answers
Ok..go to and get newest drivers by model number and operating system
remove all old printer s/w first
re install
try it again.
Posted on Aug 20, 2008
I have an HP c6389 printer i just got my new laptop and tryed to install my wifi printer so i downloaded the proper software from HP home page . But i canot install it at least via wifi . I cant even see...
Your laptop needs to be connected to your wifi network and verified by opening a web page to a new page.
The printer needs to be connected to the wifi network name and the wifi password added as well. This is normally done via the display on the printer itself.
Then the two will 'see' each other.
HP Photosmart C6380 All in One Printer Software and Drivers
Jan 02, 2018 | HP Photosmart C6380 All-In-One InkJet...
The printer turns on and I have everything
Sounds like you need a driver downloaded or re-install your soft ware. Make sure ink cartridges are installed properly.
Feb 27, 2010 | Lexmark X2690 All-In-One InkJet Printer
Lost disc to put laptop to printer can i do it from laptop with out disc
Yes, download the drivers and software here. Do nt turn printer on uniol asked by install prog to connect printer.
Jan 05, 2010 | Epson STYLUS R230 InkJet Photo Printer
I cant seem to set up my fax for incoming
Uninstall printer prog restart, then reinstall printer programme. This time sit with computer while prog installs, it will ask you question once whole prog installs, you most likely missed the information to install for the fax part?
Nov 01, 2009 | HP LaserJet M1522n MultiFunction Printer
Well the curor flickers. SO I WENT TO THE cATASIA
try upgrading your ram, cpu (desktop or laptop?)
shutdown any programs running in the 'back ground', especially anti-virus progs. they can slow the hell out of your system!! give it the 'three key salute!"- ctrl-alt-del- hit them all at the same time! keep trying 'til you get a list of running progs. shut down any you don't need running- be very careful!- there will be a menu bar at the top- read it and click on the various selections- one at a time- you see anything using a lot of ram that you don't think is important- shut it down! don't mess with any windows stuff, or you could crash your computer!! also- if you don't have any anti-virus or mal-ware progs. on your computer- install some and run them!! you may have a bunch of 'junk' messing with your os. i recommend a2 and spybots&d! free! google them and install- then update definitions- and do deep scan. may take a while, but you may be shocked at how much garbage is on your hd!! on spybots&d, make sure you run 'immunize' before you run a scan, that helps block **** that s&d has defs. for! you may need to run it more than once, until 'unprotected' shows 0. make sure it's spybots&d!! there's an 'almost' that googles up that you don't want!! you want spybot search & destroy!
also- defrag your hd! click on start-then all progs.- then accessories- then 'clean up'- after that's done 'de-fragment' hd. may take a while, depending on when the last time was you de-fragged it- if ever! may get another big surprise!!
have fun-good luck!
Oct 12, 2009 | TechSmith Camtasia Studio for PC
My Toshiba Satellite M45-S331 is veeery slow... Is there any way to reset/recover without cd?
Use a Windows Registry Cleaner SW and you will find that it gallops after that. What happens is that when you install a lot of progs and uninstall them, a lot of debris is left in the Windows Registry which has to be read over and over again when you boot up and when you run progs. Being massive in size takes a long time to read completely. If you cant find one leave your email in the Guest Book on the royaldelicious dot info. I will email one to you. Also let me know the OS that you are using.
Oct 04, 2009 | Toshiba Satellite M45-S331 Notebook
Epson problem
Here is the download page
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
Setting My Original Defaults on my laptop.
there are many ways to do this, but the fastest and easiest thing to do is to use your recovery disk provided by your pc manufacturer, as if you are going to uninstall all progs, and install all default prog from manufacturers preferences again, in this way all drivers and basic software will be there as well,
mind you that you still need to install any peripheral software you install before like printer, or electronic gadgets you want to use.
simply insert your cd and follow the step by step procedure, make sure you select 1 to recover entire hard disk
hope this helps
Aug 06, 2008 | Toshiba Qosmio G35-AV600 Intel Core Duo...
Various problems issues with my laptop soft ware hard ware
hey there,
1. you cant delete something that is from a read only file. it is impossable to do.
2. you have 2 do a degrag every week to make sure you have enough space.
3. you need 2 go into add or remove programs to uninstall your printer software. putting the disk back into the laptop is trying to tell the laptop that you want to install it but it already knows that you have that program in your system already.
Jul 28, 2008 | HP Pavilion dv1000 Notebook
OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Apr 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
