Question about Cameras
I have a canon powershot s 500. When turn it on and attempt to take a picture the screen says E18. What is the problem? Can it be fixed reasonably or should I buy a new camera? Thank you
    Brigadier General:
  • 6,966 Answers
Error Code E18 for most Canon models indicates fault with the lens mechanism, extend or retract.
Often this would just be dust, sand embedded in the delicate gears but at other times, it would be more intensive and would require parts replacement/alignment. If it could not be corrected with cleaning, perhaps a replacement unit might be better off.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
    Master:
  • 623 Answers
Visit this site for e18 error and instructions on how to fix it....
http://www.e18error.com/
    Genius:
  • 1,847 Answers
Chk this link...
  • Legin Varghese
    Legin Varghese Aug 20, 2008
    Instructions
    If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
    If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
    Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
    1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
    2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
    3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
    4) Try forcing the camera lens:
    Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
    Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
    If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
    Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
    5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
    There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 15, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Aug 02, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
I have the same issue "E18" on my powershot A95 and i don't know how i can solve it. Sorry. Loic
Jul 15, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
E 18 problem
Your A410 problem really sounds like it might be a defective CCD imager. Canon would normally fix this for you for free, including free shipping both ways. http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Unfortunately this is only for applicable cameras A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
But you may want to contact canon anyways to see if they will help.
As for your SD500 e18 issue,
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Nov 05, 2007 | Canon PowerShot A410 Digital Camera
Blank screen on Powershot S40 - I don't think it's E18
This is a problem with the CCD card. Canon has issued a recall and will fix/repair for free. Go to the Canon website and search for CCD to get more info (or call them direct).
Dec 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
