Question about Dryers
Whirlpool ler764e dryer simply stopped working
Whirlpool ler7646eq2 dryer
simply stopped working .....have checked 3 fuses(sensors) in back and they all are closed circuits.
Door switch turns on light properly and when cycled to "closed" position i hear a distinct click when operating the the start button......but nothing else.
5 Suggested Answers
gittos73
  • 244 Answers
SOURCE: Dryer won't start
all dryers use an interlock switch which when u close the door it opens the circuit for the power try banging on the front off the dryer it may start if it does then you have a lose connection to the interlock u need to get the lid of to get to the interlock switch if it doesnt start then u have a mains filter which is next to your motor about 4in in length cyclinder with at the most 4 wires going to it possible 2 wires this will having lettering and numbers on it this needs replacing its on the inside at the bottom of the casing ,8
Posted on Aug 28, 2007
SOURCE: Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Posted on Jan 27, 2009
  • 93 Answers
SOURCE: Whirlpool Dryer LER7646EQ2 Belt
sure he will if not get back to us we will help thanks from gilles
Posted on Mar 15, 2009
TheMobilian
  • 8205 Answers
SOURCE: my whirlpool dryer model number LER4634JQ1 is not getting hot
You need a 30 amp breaker in my neck of the woods. South Alabama, US
Posted on Jul 28, 2009
  • 1218 Answers
SOURCE: Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Posted on Feb 21, 2010
Have a whirlpool dryer, le9380xtwo and it simply stopped working
Remove the rear panel on the dryer and on the lower left you will see the thermal fuse that needs to be replaced. Here is the part to order.
Nov 19, 2012 | Dryers
I have a whirlpool dryer, model # LER7646EQ2 drum turns, blower works, but no heat. Pulled out heating element, no coils broken or grounding out, however part of heat sheild is blackened. Before it...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Whirlpool Dryers
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer stopped running mid-cycle. I've checked drum belt; it's okay. I've checked electrical connections; they're okay. I haven't checked any fuses--don't know where they are. What's wrong?? MODEL:...
THIS STILL SOUNDS LIKE AN ELECTRICAL PROBLEM TO ME, MAKE SURE YOU HAVE 220 VOLTS FROM DRYER RECEPTACLE, 110 ON EACH SIDE OF RECEPTACLE, IF YOU DO NOT RESET THE BREAKER FOR THE DRYER, IT JUST DOESNT SOUND RIGHT STOPPING LIKE THAT WITH NO OTHER PROBLEMS,CHECK THIS LET ME KNOW THKS LARRY
Apr 25, 2010 | Whirlpool Dryers
Whirlpool DWJR - ELE, Model LER7646EQ2, about 12 yrs old.
belt may be broke since you hear the motor running.
Sep 22, 2009 | Dryers
No heat in electric dryer model LER7646Eq2
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail in your dryer are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open.
Aug 25, 2009 | Whirlpool Dryers
Dryer runs as usual but won't heat up.
you need to check continuity across the heating element with an ohm meter looks can be deceiving
Apr 14, 2009 | Dryers
Mar 15, 2009 | Whirlpool LER7646E Dryer
Dec 30, 2008 | Whirlpool LGR7646E Dryer
Whirlpool gas dryer model number ler7646eq2 does not produce heat
Need more info. Does it rotate? If it has a viewing door on the front, you may see if the ignitor is glowing. If the ignitor glows, the ignitor (flame) sensor may be bad, and the ignitor will shut down.
Aug 09, 2008 | Whirlpool Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
