Question about Panasonic Office Equipment & Supplies
Model KX-FHD331 WILL NOT RECEIVE ANY FAXES. SETTING THE TELEPHONE MODE KEEPS MOVING TO FAX ONLY. WE DO NOT RECEIVE A TELEPHONED FAX ON THE MACHINE. PLEASE ADVISE OR CALL ME AT 706-629-8641. THANKS JACK D.STEPP
WE WERE SETTING FOR TELEPHONE INSTEAD OF FAX ONLY. OUR MISTAKE IN THE SETTING.
THANKS ANYWAY, JACK D. STEPP
Posted on Aug 21, 2008
How to keep auto answer mode
Panasonic KX-FHD331 has Receive Mode Button (Just beside Display screen)at the top control pannel, as shown below: -
Press the button "RECIEVE MODE" Button and set the Fax to "FAX MODE ONLY" and the fax will automatically answer the calls in your absence. For further information you may refer to Page-52 of the Operating Instructions Manual.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Mar 31, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Hook-up
Cable telephone lines are DIGITAL, fax machines are ANALOG devices. It will not work reliably on the ComCast line.
Dec 19, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Recieving faxes automatically
you have to set machine for fax mode by pressing auto answer button on key pad of machine. then you have received faxes automatically.
May 04, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
95 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
