Question about E-Machines eMachines Desktop PC
System Recovery message appearing during boot up for no apparent reason
In the last couple of days, when I boot up my computer the Emachines logo appears, and then the next screen has the text "Press F11 to start recovery". This message counts down for 2 seconds and then windows boots up as usual with no problems. There is no text other than "Press F11 to start recovery" that appears, which is why I am thinking there is no serious problem here. Is this a boot-up option that is possibly selected to appear that I can turn off? The only real change I've made in the last few days is that I changed my monitor connection from a VGA wire to a DVI. Thanks for your help.
  • Ribery7 Aug 28, 2008
    I actually switched the wire back to VGA and everything is back to normal. If I do try and switch to DVI and the same thing happens again I will be sure to come back for help. Thanks.
    Brigadier General:
  • 5,158 Answers
The change would be in your bios i believe. are you comfortable with working in there ?
Robert
Posted on Aug 27, 2008
SOURCE:
Problem getting recovery disk
I understand that you want to reinstall the Operating System on the computer. Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer. To start the system recovery:
  1. Restart the computer
  2. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. When prompted with a boot screen, hit the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Recovery Media.
  1. Insert the disk labeled System CD into the computer's disk drive and restart the computer.
  2. When the eMachines logo appears on the screen, press the F12 key repeatedly.
  3. Select either CDROM or DVD as the boot device, this may vary depending on the system.
  4. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  5. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  6. After the system recovery program has loaded follow the prompts to reinstall the operating system.
Refer the URL for more information and for the link to order the Recovery media if required.
Nov 15, 2013 | eMachines T Computers & Internet
My emachine ET1831-03 crashed a few months ago. All I can get it to do is display the windows boot manager screen. It says windows failed to start, and gives me status: 0xc000000f NLS data is missing,...
Power off the computer, then restart it. As soon as you see the eMachines logo appear on the monitor screen, press the "left-Alt" and "F10" keys simultaneously. Wait a few seconds for the Windows boot screen to appear, then press the "Enter" key.
Click the "Restore Operating System to Factory Defaults" option after the eRecovery Management window appears. In the Notice window, read the warning that states all information on the drive will be lost, then click the "Next" button.
Click "Next" in the Restore Destination window, then click "OK" in the final confirmation window. The eRecovery Management utility formats your main system drive and reinstalls the original software that shipped with your computer. A progress bar notifies of you of the current progress of the recovery. The recovery utility may prompt you to restart your computer several times during the recovery process. Restart the computer when prompted. The computer reboots automatically after the recovery finishes and launches the Windows First Time Setup. The recovery takes between 10 minutes and one hour depending on which model eMachines computer you own.
Follow the onscreen prompts to customize and personalize the Windows installation on your eMachines computer. Log in to Windows with the username and password you choose during Windows Setup.
Dec 13, 2017 | Computers & Internet
Aspire one kav 60 would not boot how to recover it or restore it???
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 15, 2011 | Acer Aspire One PC Notebook
I have 2 problems. My Acer Aspire 560z keyboard types garbage for some reason, so I am using an external KB. Then, I want to restore the laptop to factory settings, but the cd's are lost. I don't...
Keyboard - Do you have the NumLock on?
From the ACER support site:
Aug 12, 2011 | Acer Aspire 5610 Notebook
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
Troubleshooting asus eee pc 900 series acts like its gonna boot then my scream goes black. HELP
If your computer is less than a couple years old it should have its own recovery partition you can boot into. For Acer laptops it is usually pressing F9 just after starting the computer from off power, from there you should follow the steps to recover your operating system to an older time. Preferably the last time you used Windows Update (there should be a highlighted date in the calendar that pops up).
Also note that if F9 does not work look around the bottom of the screen when the Acer logo appears during startup to see what button is for System Recovery or something of the sort.
If this does not work or no option for system recovery is available please post back here and I will have more instructions
Jun 17, 2011 | ASUS Eee PC 900 PC Notebook
How do i reset my accer aspire 5336 laptop to factorydettings
This information can be found on the support page of Acer.com
http://acer.custhelp.com/app/answers/detail/a_id/2631
How do I reinstall the Operating System on my computer?
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Thanks for using FixYa.com
Apr 28, 2011 | Acer Computers & Internet
Is there a system recovery disk for the emachine ET1161-07 desktop pc?
If you bought the computer new and did not receive a recovery disc with it then the recovery software can be reinstalled from a hidden drive built into the computer.
The steps for re-installation:
  • Restart the computer
  • When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  • When prompted with a boot screen, hit the Enter key.
  • After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If you bought the computer used try the above method. If that fails then it came with a recovery disc but you didn't get it with the computer. The only thing you can do is contact eMachines support for help or purchase a new copy of Windows and reinstall it with that.
I hope this helps. If not and you need any help with reinstalling a new version of windows please let me know.
Oct 22, 2009 | eMachines ET1161-07 Desktop PC
I have an emachines computer with vista...need to restore it back to factory settings, however, i cannot find the emachines program file in my start menu...any suggestions?
If you notice your disk drive having a partition for recovery, you may have an option to do system recovery from boot up.
Most desktops have this option during the boot up process. So before windows logo appears on Startup, press F11 key.
This procedure will restore your computer's system from the very first time you used it. So, better back up all the important files and documents before doing this.
Oct 13, 2009 | E-Machines (T2958) PC Desktop
My computer lost all its memory and is claiming to need a system recovery cd where can i get it
System recovery can be accessed during initial boot up before the Windows screen comes up. In most cases you need to press F11 to begin system recovery. There should be a message that flashes across the top of the screen shortly after you turn on the computer that instructs you to press F11 for emergency recovery. Do it. If you do not see a message, try pressing the F11 key several times right after you start your computer, sometimes the message to enter recovery does not appear because the manufacturer places there logo page on the initial screen.
Jun 07, 2008 | ZT Group CISNET A7050 PC Desktop
E-Machines eMachines Desktop PC Logo
54 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
