Question about Refrigerators
Appliance installation Thankyou CMV9 ! It sounds like I will be placing the wiring on the range under screws whereas on the dishwasher I will have to connect wire to wire.Is this correct? I read somewhere on the internet that the tape around the water outlet for frig is not needed due to the self tightening mechanism when you screw the copper water line on. Please comment on this. I have used plumbers tape when installing sink faucets. Is this the same kind of tape you are speaking about? Thankyou for your time. Based on what you are telling me so far, I believe I can install the range and the frig sounds like you simply screw the copper waterline on after applying the tape.
  • 594 Answers
On the fridge.. sometimes the teflon tape is not nessesary. i just like to use it for the extra measure. teflon tape is in a blur roll with a white pop off cover and the tape it's self is a thin white tape.
on the dishwasher.
alot of the time you will be hooking up wire to wire. On the model you will be getting it may be as simple as even a black wire and a white wire. You may also need to purchase a plug that will plug into an outlet. but i am not sure what model you are getting so i do not know the exact specs on it. it also should come with an installation guide to help you through the process.
Posted on Aug 20, 2008
How to test a defrost tstat at room temp
Directions for testing a refrigerator defrost thermostat.
Before you begin to test your defrost thermostat, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
  1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
  3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
  4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
  5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
Oct 28, 2012 | Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
My amana 26 side by side refrigerator/freezer keeps running and everything is freezing. i have tried to turn it down with no help
1x1.gif How To Replace the Temperature Control Remove the temperature control dial or housing. Pull the dial straight away from the wall. Remove the temperature control. If there is a housing over the control, it either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring.
Before replacing the control, unplug the refrigerator to avoid an electrical shock hazard.
The control is connected by two wires. Label the wire placement on the control before disconnecting the wires. The wires are connected to the switch with slip-on connectors. Firmly pull the connector (do not pull on the wire) off of the control's terminal. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors for corrosion. If the connectors are corroded they should be replaced.
The temperature control also has a temperature probe permanently attached. Follow the path of the probe and remove any fasteners that hold it in place.
Carefully replace the temperature probe along the same path as it was originally installed. Avoid any unnecessary bending, and do not bend it into a sharp angle as this can damage the probe. Connect the wires to the new temperature control. Replace the switch and housing (if any) and press the knob onto the the control's hub. Adjust the control to a midway setting. Plug in the refrigerator. After one to two hours check the temperature.
Aug 13, 2011 | Amana Refrigerators
Kenmore refrigerator keeps running. We have tried differant temperature settings. Frig will not turn off. At the coldest setting the freezer does not completly freeze the food. Will not make ice cubes.
Sounds like a sealed system issue.
If the appliance is more than 3 years old OR it was repaired in the last 6 months, it may be a leak on the sealed system, so there is not enough refrigerant and it can't reach the adequate temperature.
You can try this:
1. Clean the back coils. remove all dust. (perhaps the coils are at the bottom).
2. Use a fan and blow some air at the coils. Check if temperature lowers. If so, perhaps the evaporator fan is broken.
3. The sides of the appliance are hot? Any recent service? Perhaps the technician forgot to connect a wire.
4. Unplug the appliance and wait about 10 minutes, then plug it back to the voltage. Check if the problem continues.
5. Where is the location of the appliance? Next to the range? In the garage? If the fridge is located on a hot place, it will not cool down properly.
If everything of above looks ok, then you may need to contact a technician. Check the warranty information in the user manual. Some appliances have a good warranty coverage.
If appliance is more than 5 years old, it may not be a good idea to repair if sealed system or compressor is broken. It will be quite expensive and repairs will not last long.
Good luck.
Dec 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
Little piece in freezer broke, the one that turns light on and off when you open the door, stanless steel side by side. Can I order the part and fix it myself or do I need to have someone come out to fix...
Sounds like you mean the light switch. Purchase new one at your local appliance parts house. Look closely at it. Ask the counter man if it installs easily. If so, take it home, UNPLUG THE MACHINE OR SHUT OFF THE CIRCUIT BREAKER. Pry out old one, Attach wires to new one. It should just snap in place.
Oct 10, 2009 | Refrigerators
Freezer does not freeze things, ice cream is liquid
Check:
(You may need to remove the back cover for next two steps)
* Is the fan in the back of the appliance working? If not, use a fan a blow some air in the condenser.
* Is the condenser clean? remove dust, lint and other particles.
* Is the appliance installed in the garage, a hot location, or closed to the range? You may need to place the fridge in a better location. Some kits are available if the appliance needs to be placed in a hot location.
* Is the thermostat low? Try to "increase" the temperature to "colder"
* Is the fridge door closing properly? Check the seal around the door if it closes perfectly.
If nothing of above works, it may be caused by:
* Broken thermostat.
* Failure on the sealed system
Good luck.
Sep 01, 2009 | LG LSC26905TT Side by Side Refrigerator
Dishwasher will not start up.
Hello, I solved this problem. I opened the front of the dishwasher (top) and replaced the thermal fuse and then looked at the mother board. The service company had placed two wires back onto the mother-board and were placed in the wrong slot. I moved the wires back to the right location and the dishwasher has since washed to loads without any problems. The service company has been fired.
Thank you for your help,
Jim
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
you can hookup the dryer no problem.... and the fridge as well.
the dishwasher may be a little more complicated but i will explain it to you and you can judge for yourself.
I will start with the stove.
1.On the back panel of the stove there will be a small 6inX3in panel with a screw holding it in place.
2.You will need to remove the screw.
3.Once this is done you will see a black box with 3 either screws or bolts with nuts on them.
4.You will need to remove the screws or nuts.
5.You will probably get a dryer cord that has a green,white,red,and black wire it.
6.You will need to take the white wire and put it in the middle connection.
7.you will need to take the red wire and connect it to the left side connection.
8. You will need to take the black wire and connect it to the right connection.
(make sure all the screws and or bolts are secure.)
9.take the green wire and you will connect this to the back of the stove using the green screw or the screw that hold the panel in place. (Put the panel back in place,take the wire and put the screw through the opening in the wire and screw back to the panel to hold the panel and wire in place)
10.plug the stove in.
now for the fridge.
1.on your copper line there should be a end on it that will screw on to the water pump on the fridge.
2.take some teflon tape and rape the threads of the pump where the line will connect. (make sure you wrap the threads in clock wise.)
3.connect the line making sure it is secure.
4. turn the water on to the fridge.
now the dishwasher.
1. you will need to connect the water input lines. i would use teflon on the connection to make sure it does not leak.
2.connect the drain.
3.connect the wireing.
make sure that the breaker is off when you do this.
you will need to color match the wires. there should be a black,white and red wire. once this is done turn the breaker back on and run your dishwasher through a cycle to make sure it works correctly.
you will be done. please use the direction for the dishwasher at your own discretion but do please be CAREFUL.
please do not forget to rate and comment about your experience with fixya. Have a good day.
Aug 20, 2008 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
