Question about HP Office Equipment & Supplies
I am using a HP 2610 all in one printer on Windows XP and continue to get the following message at startup: HP Digital Imaging Monitor {CUE} has encountered a problem and needs to close. AppName: hpqtra08.exe AppVer:43.15.0 ModVer: 0.0.0.0 Offset: 35535051
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ok..my recommend
remove all software with add/remove program
go to www.hp.com and get fresh set of complete drivers for your model by operating system
re install
try it again
Posted on Aug 20, 2008
How do I use the scan feature on my HP Officejet J3680 All in One. I pressed the "scan" button and received message "No scan option, refer to device documentation to troubleshoot". I do not have "device...
The HP Digital Imaging Monitor (DIM) software must be running in order to scan from the printer.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor .If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software.
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
  8. Try scanning again
Regards,
Riztech
Jun 16, 2010 | HP J3680 Officejet All In One Printer
"No scan options, refer to devise docs."
Hi
I have provided the troubleshooting doc, please follow this to resolve the issue.
Solution:
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 14, 2009 | HP OfficeJet J4580 All-In-One Laser...
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
When I hit scan it says "no scan options"
Hi just follow the below steps and the problem will be resolved.
Solution:
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Dec 28, 2008 | HP Officejet J5780 All-In-One InkJet...
No Scan Options
Hi
i really understand your concern.I have a document that i prepared to solve this particular issue.This will help you alot
Solution
3.Click OK .
Windows Vista
1.Click Start .
destination list.
6.Click Settings .
software.
14.Click OK .
5.Click OK .
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 09, 2008 | HP OfficeJet 6310 All-in-One Printer...
Scanner doesnt work
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Step four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 14, 2008 | HP Officejet J5780 All-In-One InkJet...
I am trying to scan a pic and my scaner says no scan options
  3. Click OK .
Windows Vista
  1. Click Start .
  2. Click Settings .
  9. Click OK .
    3. Click OK .
Jul 08, 2008 | Office Equipment & Supplies
Have HP Photosmart C7200 and want to scan document to computer but there is no 'Scan to computer' choice to slect on copier scan menu as instructions direct.
I had the same problem and just found the solution.
Solution one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. If it is running, the DIM icon (c01404188.gif ) is present in the notification area. The notification area is located in the lower-right corner of the computer by the clock. Figure 1: Notification area c01404189.gif If the DIM icon is in the system tray, you do not need to complete this procedure. Skip to the next solution. Follow these steps to set the computer to run the DIM.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ).
  2. In the Start Search text box, type msconfig , and then press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window appears.
  5. Select the HP Digital Imaging Monitor check box. If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Reinstall the software to resolve this issue.
  7. Click Yes to restart the computer.
  8. Attempt the scan again.
Jun 06, 2008 | Office Equipment & Supplies
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cardridge problem for my 5610v
try with another cartridge, maybe you have a faulty one.
try cleaning the connectors on both printer and ink cartridge.
Nov 21, 2007 | HP Officejet 5610 All-In-One InkJet...
63 people viewed this question
Ben Johnson
