Question about Canon imageRUNNER C3220 Color Copier
Unable to set up scan feature.
I work at a UPS Store in rock hill sc, and we are unable to use the scan option on the imagerunner c3220. i have even asked the guy who works for canon to help, but he says he has tried to set it up before, but doesnt know how to do it, so anyway, i know a good bit about computers and i am pretty sure if someone explained it to me, or showed me where i could find an online guide describing how to set it up i think i could do it myself. We are running an xp pc on a dsl connection. thanks for your help!!!
  • 3 Answers
First question is do you have universal send on the copier. If you have a Send tab on the touch screen you have it, if you only have a scan tab you do not.
With the send tab you can set the device up to scan, create a file and send it to a network destination. With the scan button you have to install the color network scan gear program on your computer.
http://downloads.canon.com/cpr/software/imagerunner/CNSG230.exe
This software is just a twain driver that interfaces with the copier through the network. It does not give you any software to drive the scanner, it only gives you a choice for the copier in your list of scanners. You have to use some other program (i.e. Acrobat standard or MS document imaging) to drive. After you install it open it up, let it discover the machine on the netowrk and close it. The interface only points to the device on the wore, it is not directly used for scanning.
If you have a send button I would recommend for your situation that you scan to a shared folder on your desktop. First you create the shared folder, and make sure you can see it from another PC on the network. If your other PC's can't see it the copier won't either. Create a user on the computer with the shared folder for the copier to use. Set that users password to never expire.
Press the additional functions hard button
Press the touch screen button for address book
Add an address to address book # 1
The type of address will be SMB
Register a name for the address (Scan to PC is fine)
there should be a browse button on the screen, press it
Use the up and down arrow to browse up and down the tree
when you see your network browse from the domain to the PC you are scanning to
When you try to expand the PC you will have to enter in the user and password you created for scanning
point to the shared folder you will use
OK your way back out to the user screens
Have fun scanning
Posted on Aug 22, 2008
  • Canon Expert
  • 1,326 Answers
The first question is...... Did anybody Load the software to scan on your computer and or network?? Also, are you able to print to the copier or is it a stand alone copier. If your repair person can not set it up right, ask him to send his "IT" or "Network Person" If you have a network the software needs to be installed on that and you will need your "IT" person to give the password for the network.... It's alot of work and most copier companies charge extra for that funcation you are asking about..
My c3220 can not print. my technician told me it has no printer card in it
It could be true, you should check your bill for referance, the COPYER comes as a plaine COPYER, all other boards are optional, including USB and ETHERNET boards, if you think of getting one I suggest the ETHERNET board for network printing and scan to e-mail features...
Jul 26, 2011 | Canon imageRUNNER C3220 Color Copier
How come i can't print on 4 3/4x6 1/2 envelopes? The envelopes keep getting jammed in the machine.
try the bypass.... if unable to print via bypass then clean rubber bypass feed rollers with alcohol... next step... see if it jams at the finisher... if so set the machine to exit from an internal tray... if it has one...
Dec 12, 2009 | Canon imageRUNNER C3220 Color Copier
How do I sent my Canon ImageRunner C3220 to copy in black and white as the default?
First set it to B/W on screen then in additional functions /copy settings/page down to store settings then store and reset to quit.
Nov 24, 2009 | Canon imageRUNNER C3220 Color Copier
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon Color Imagerunner c3220
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
Sep 03, 2008 | Canon imageRUNNER C3220 Printer
Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
Aug 01, 2008 | Canon Color C3220 Copier - Color...
ImageRunner 3570 cannot scan
Do you have a "Board Scanner"? It's Option, you must buy it.
Mar 19, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon iR C3220 Control Panel
Hi Ing,
I am not "at" a 3220 but I will try to visualize. On the "op" panel to the right of the display is a button that looks like an asterisk and says additional funcions.Press it. Bottom left tab says "system settings". Press it. New menu,right side , second tab, says network settings. Press it. At that point you should see tcp/ip settings. Press this tab and you will see the ability to manipulate many of your network settings."NOTE" this device is indeed capable of supporting being set to DHCP. You of course understand the pitfalls of having a printer set to dhcp. It is almost always recommended that a printer/scanner/fax/document server/ have a static ip address. However the right IT person in the right network enviromentwill have no trouble at all with this device. hope this helps, and if I did help please let "FIXYA" know it .Good luck and take care. .....................SPINAL........
Mar 12, 2008 | Canon imageRUNNER C3220 Color Copier
Fax results page
Try turning on fax confirmation in the fax user settings.
As for the scanning problems try downloading the latest scangear driver from canon usa website and load it.
if you require more help please get back to me
thank you
Feb 26, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
735 people viewed this question
old marine
old marine
