Question about Microsoft Windows Server Standard 2003 for PC
Disable usb pendrive,cd rom and floppy in win2003
Hi
my name is amit patel
i want to disable usb pendrive,cd rom and floppy drive in win 2003 server
This is very good
Posted on Aug 25, 2008
  • 435 Answers
You can lock the USB drive by editing the registry. So I’ll tell the key name and the value, that you have to create for the restriction. If the key is not present, then simply create it.So here we go:
Restrict Writing to USB Drives:
HKEY_LOCAL_MACHINE\SYSTEM\Current Control Set\Control\StorageDevicePolicies
Create DWORD value WriteProtect and set its value to 1
ALso, please click on the link mentioned below for more information:
http://support.microsoft.com/kb/278295
http://support.microsoft.com/kb/231289
You can also use third party software to lock the USB drives:
http://lock-usb.qarchive.org/
Thanks
Posted on Aug 22, 2008
Dell poweredge 830 cd-rom unknown bios
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Apr 13, 2012 | Dell PowerEdge 830 Server
I have a emachine netbook and it say no bootable device
Failed hard drive (assuming one is installed), or could be that it has "lost" the Windows installation.
Possibly a virus, you need to reinstall windows, or hopefully, repair the installation
To do this, as this does not appear to have a DVD rom, you will need the following:
  1. A legit copy of windows (whichever is installed currently)
  2. A spare computer or preferably an external USB DVD Drive (if the latter, skip to the end)
  3. The SATA drivers for this laptop (essential if using windows xp, may not need if vista)
  4. a USB pendrive of at least 4 GB
  5. A USB Floppy drive (possibly)
  6. a copy of win to flash
http://wintoflash.com/home/en/
Uisng the spare computer, extract the contents of the Windows disc to a folder on the spare computers hard drive. Run win to flash and follow the instructions, it will build a boot copy of windows on the pendrive that you specify (it will format the pendrive also).
Copy the sata drivers to the USB floppy drive (you might get away with copying them to the same usb bootable you have just made but I doubt it)
Now, in the bios, set 1st boot to USB drive
Then boot and install, when you reach the F6 prompt, point it to the usb floppy drive and let if find the sata textmode drivers.
Its hould then find your existing windows installation and repair it
IF you ahve a USB DVD / CDROM drive, ignore the above and just install from that, you may need to use a floppy usb to install the sata drivers though
Feb 08, 2011 | Acer eMachines eM2501162 Netbook
I WANT TO INSTALL 2003 SERVER ON IBM X236 BUT IT IS SHOWING NO DRIVE PRESENT
Use the IBM configuration disk and it should be able to prepare the server for what ever OS you need to install. If you don't have it then, try redoing RAID and reformat the hard drives and try again..You can probably hit F6 during the initial portion of the install and supply the necessary SATA drivers on a floppy and get it to install. You will probably need a USB floppy though unless your server has a floppy drive.
Insert your Microsoft Server 2003 Installation disc into the CD/DVD-ROM drive and boot the server from the installation disc. Microsoft Setup will load the files it needs to perform an installation. Press "Enter" to setup and install Windows.
  • 2 Press "F8" to accept the Microsoft License Agreement.
  • 3 Create a new partition to install the operating system onto by selecting the "Unpartitioned Space" and pressing "C." If there is no unpartitioned space, highlight and delete all of the other partitions on the hard drive by pressing "D." Set the partition size to the "Maximum Size" and press "Enter."
  • 4 Format your new partition with the "NTFS" or the "NTFS (Quick)" option. Windows setup will format your hard drive and load the installation files. Your IBM Netfinity will restart and installation will continue.
  • 5 Select language and regional setup information, then press "Next." Enter your name and company name, then press "Next." Enter your Windows 2003 Server Product Key and press "Next."
  • 6 Select the licensing mode you would prefer to use and press "Next." Create an administrative account and password and press "Next." Enter the current time and time zone and press "Next."
  • 7 Setup your Network information by naming the server and defining how it will connect through the net. Press "Next" to navigate through the network setup screens. Windows Setup will finish the installation process and provide you with a log-in screen to use your computer.
  • If you delete old partitions from the hard drive to install Windows Server 2003, you will lose all information on those partitions.
    Jan 20, 2011 | IBM eServer xSeries 236
    Ths screen displays ERROR,Expansion ROM not initialized-PCI network controller on Motherboard. Bus:04,Device:04,Function:00 how do i fix this? I am trying to install win 2003 server ,system not...
    The ProLiant ML110 server with System BIOS Version 16 supports a total of eight IPL devices. Four IPL devices, such as the IDE controller and the floppy controller, are integrated, leaving support for four additional PCI IPL devices (i.e., PCI card plugged into PCI expansion slots); however, the ProLiant ML110 has five PCI expansion slots. Therefore, it is possible to configure the ProLiant ML110 with five PCI IPL devices (such as SCSI controllers or NICs) and exceed the limitation of System BIOS Version 16
    The resolution to the problem is to update the System BIOS Version 17 which supports a total of nine IPL devices and five PCI IPL devices. Update the ProLiant ML110 server to System BIOS Version 17
    i could not include the url for the download because you did not especify the generation of your server
    but follow this link
    1.select your server with the corresponding generation
    2. select the operating system
    3. from the download list select the bios update to a bootable usb or diskete
    4.install the os
    Oct 27, 2010 | HP ProLiant ML110 Server
    My laptop won't boot from cd
    to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
    Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
    Can not boot dell 6650 from external dvd
    Have you checked boot device options....from BIOS
    Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
    Insert Boot media or DVD-Win2003, to DVD-ROM device..
    reboot Server, try now
    If still issue.. Check to boot Server using some other media..
    if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
    Oct 06, 2009 | Dell PowerEdge 6650 Server
    I need a driver for my sound card
    how i solve problem plz contact yhis email shaurakhkhan@yahoo.com
    May 28, 2009 | IBM Computers & Internet
    Os instalation will not load
    Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
    1st boot device = [Floppy disk drive]
    2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
    3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
    Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
    If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
    Or is this not the issue you are having?
    Mike
    Sep 26, 2008 | Computers & Internet
    How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
    helo frind
    1. Windows Xp installation disk
    2. Access to PC with working CD Cd-ROM DVD drive.
    3. This file solution.rar
    This guide is for people with basic knowledge of PC hardware and system software
    Let's start.
    1. Download solution.rar file
    2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
    3. Put your pendrive ( at least 1GB) into working PC USB port
    4. Go to the folder C:\Dos and run HpUSBformat.exe file
    - it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
    - set other options like on the image below and click start.
    - now you have a pendrive with bootable dos on it.
    5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
    - your pendrive should look like that
    6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
    good_lk
    Oct 12, 2007 | Microsoft Windows XP Professional With...
    Microsoft Windows Server Standard 2003 for PC Logo
    69 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
