Question about Canon CanoScan LiDE 500F Flatbed Scanner
I need a user guide for canon lide 50 scanner
Preferably pdf file
  • Anonymous Nov 02, 2008
    I need instructions for using the 35mm slide scanner.
    President:
  • 2,692 Answers
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
Lost my instructions help
Click on the link below to download the user guide, drivers, and software for the CanoScan LIDE 25 scanner
http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25
Oct 12, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Needs canoscan drivers
Drivers are specific to the operating system (ie drivers for Windows XP may or may not work with Vista). Click on the link below and you will be navigated to the Canon driver download page. Choose your operating system (OS) from the drop-down menu, your preferred language and you will be ready to download the drivers.
CanoScan LiDE 600F
Oct 05, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Is there a manual that shows how to scan slides
Here is the support site for your scanner:
Canon LiDE 600F Support
Under the Drivers & Downloads there are a couple manuals. The Quick Start Guide, which is a PDF file and the On Screen manual which is an exe file. The PDF will open right up. The other you will need to download the file to your desktop and when the download completes you need to run (double-click) the file to install it.
Note: This scanner does not support scanning of Mounted slides. (See Footnote #5 on Page 9 of the Quick Start Guide.)
You may be able to unmount the slides carefully and follow the instructions for scanning film. You might try that on a less desirable slide before unmounting them all. Just a suggestion.
Thanks for using Fixya.
Sep 29, 2009 | Canon LiDE 600F Led Printer
Lost setup disk 4 my Canoscan LiDE 100
This is Canon Support, and the support page for the CanoScan LiDE 100,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=17104#DownloadDetailAct
On this page you'll see the file downloads, for the User On-Screen Manual. Both for Windows or MAC.
There is also a Quick Start Guide, that is in PDF file format that you can download.
At the top you'll see the heading -> Drivers/ Software Selection.
Under that it states, "Please select your Operating System to view available drivers and software"
You just click on the blue down arrow to the right of the box, then left-click right on the Operating System you're using.
Not knowing what Operating System you're using, I chose Windows XP as an example:
After you click on your Operating System, the drivers immediately appear, (At least they did with Win XP)
Under the Drivers heading, and the sub-heading, File Name and Description,
it lists -> LiDE Scanner Driver Ver 14.0.1 (Windows Vista/Vista 64/XP/2000), then has -> smwin131en.exe <- in Red.
This is what you click on.
You'll be taken to another page, where you click on -> I agree
From there you should get a small pop-up window. It may be a 'Squawk Box' from Microsoft. "Warning this software, ya-da, ya-da"
It's okay. Click on Run. Then click on Run again.
This is if it's going to be used on the computer you're using to operate the scanner on.
If not, click on Save.
If you don't have your downloads saved to go to your My Documents folder, it will go to your desktop screen. Remember, or write down the file name, so that you can find it later, then click on Save.
Burn this file to CD disk. After you install it into the computer you want, you may have to go to My Computer, (Start>My Computer),
and double-click on your CD/DVD drive letter,(Example: (D:)
May 09, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Lost the manual
You can download the scanning guide here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=119&modelid=6624#DownloadDetailAct
Run the installer, then double click the index.html file to load the table of contents.
Good Luck (you may need to search for 'LiDE2030' if you can't find where you downloaded and extracted the files)
Nov 17, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LIDE 60 flatbed scanner software
You can download the necessary drivers here:
http://www.driverfiles.net/Scanners/Canon/CanoScan-LiDE-60/download/page,sh,39262,430,11,.html
and the manual, in case it is missing, here:
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/CANOSCAN-%20LIDE%2060-_E
It shouldn't be necessary to download the 'Recommended' "DriverDetective." I believe this is a commercial program.
Sep 09, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon Canoscan LIDE 50
Hi am gonna provide you with the link from where you can download it, keep it mind that if you have changed operating systems, then the scanner might not be compatible with you current operating system. For instance if you had Windows ME or Windows XP but currently have Windows Vista there might be some compatibility issues. Good Luck! http://drivers.softpedia.com/progDownload/Canon-CanoScan-LiDE-Download-816.html
Jan 19, 2008 | Canon CanoScan LIDE50 Flatbed Scanner
Canon CanoScan LiDE 500F Flatbed Scanner Logo
old marine
old marine
