Question about Edirol UA-4FX External Sound System
Sound device and usb device not working
Dear All
i have assembled pc last one year i am using and it is working fine but suddenly my HDD gave some problem and i have to reinstall windows system. but after that my sound device and usb device is not working. i tried lot of option. mother board is conroe 865GV anyone will help me what to do?
other than sound and usb my pc is working fine.
  • chandrahas Aug 21, 2008
    thanks for your reply but i did everything. but no problem i will do it again.
    thanks
    take care
    God bless you
    Master:
  • 763 Answers
Maybe you didnt install the driver for *********** board. try to install the driver and see what happen. the cd driver of a motherboard includes the driver for usb, audio, network, etc.. hope that helps!
CHARCOIS
Posted on Aug 20, 2008
  • Charris Suaybaguio
    Charris Suaybaguio Aug 20, 2008
    the * is motherboard. correction
Hdd 2tb only showing in device & printers
Sounds like you require new drivers for the USB sockets. Only use Acer drivers, Microsoft are not trusted to work without issue.
Acer Explore Beyond Limits
Aug 30, 2016 | Acer Aspire V5-571P-6835 15.6" Touch...
I do need to reinstall driver for WD Ext HDD 1021 USB Device - wdbaau0010hbk-01. Where I can find it?
The USB HDD driver is built in on XP. If the drive is not recognized try the following;
  1. If you usually plug it into the front USB, Try the rear USB
  2. Try a flash drive in the same USB and see if it works
  3. Plug the HDD into the USB then look in Device Manager for it, Right Click and click Update Driver then select Windows Update for the location.
Dec 07, 2013 | Western Digital Elements Computers &...
Help! XP stopped recognizing my external hard drive. It has worked fine for two years and then suddenly: My Laptop no longer "dings" when I plug in the external hard drive. There are no unknown...
No question is silly dear, problems are there and we are in this site to help.
Yes, you mentioned that the said device works fine with your desktop, then it is probably not the problem with your device. You have also said that your tried formatting the os. Good.
Hope your pc, laptop and the memory device are disinfected with a good, licensed and updated antivirus.
Check, if Universal Serial Bus Controllers (corresponding to the nos. of total usb port present in the machine) are present and enabled both in the device manager and the bios as well and set to Hi-Speed if it is Full-Speed.
Well, have you tried formatting the memory stick/device? Format it and see if it works.
Next, please change the usb connectivity cable using/attached to the device and see.
Another thing while connecting an external storage device like ext-hdd. The external usb storage devices that gets connected with a usb cable, in some rare cases needs to be connected as a usb-master or usb-slave [you can see many external usb drives comes with a splitted or dual usb port connector cable, this is either for connecting two usb device or to connect as master when used as a single drive], therefore use such cable to connect and use alternated ports, and see which works.
Now, if all above fails, it then might be the problem with your external drive, i guess.
Best to seek help of your system admin/vendor.
Oct 16, 2011 | Microsoft Windows XP Professional
No sound output on highlander dvd recorder/hdd(80g). We did have for nearly a year, but a month ago sound output stopped. ie. we can burn from hdd to dvd & play in another machine & it has sound -...
Ive just had the same thing happen to my highlander dvd/hdd 160g.
Mine lasted just over a year and I have lost the sound as well. It worked perfectly and No problems until sound suddenly disappeared
Nov 19, 2009 | Televison & Video
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
Voice stopped working suddenly
Sounds to me ethier the mute is on and not showing or the speaker is out
Aug 30, 2009 | Tomtom ONE 3rd Edition GPS
Laptop suddenly stopped recognising my external USB hard drive
I had the same exact problem with a WD2500xms passport. The problem was the USB cable. I went to the store and bought a 6' USB cable ( $26 at Radio Shack) with the same specs and now, no more problems. Also I called WD technical support (800.275.4932) and asked for a new cable. The WD customer serverice was very helpful and said it would sending me a new cable for free. When it arrives I'll return the 6'er.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Toshiba A200 sound problem ''no audio devices installed'' error
its the driver update . revert to your last good sound then check web for download adresseing your problem sometime just some small setting changes does it any other
Jul 31, 2009 | Computers & Internet
IPAQ 1950 suddenly will not connect to PC to allow sync
Same problem, on four computers with two iPAQ 1950's. I installed ActiveSync 4.5, and all works fine now. This link will get you to AS 4.5:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-register.mspx
This SHOULD work for all PDAs, but I have only used it for the 1950.
Nov 11, 2008 | HP iPAQ rx1950 Pocket PC
Edirol UA-4FX External Sound System Logo
55 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
