Question about Toshiba Satellite A135 Notebook
Harddrive does not kickin
When I power up my computer the power stays on the screen remains blank and the harddrive lights up for about 2 seconds and then shuts down. Any idea as to what might be causing this to happen. also not sure if it is related or not but 2 days prior to this happening all of my usb ports stopped recognizing all of my hardware
  • 24 Answers
It sounds like you had a mother board failure. its probably not fixable but i would still suggest taking out the computers ram and sticking it back in. i have ran into issue of that before. but from what your saying your computer wont even get to post( power on self test) which indicates a hardware issue. given you said that the usb stopped working on you i would say something fried on your motherboard.
Posted on Aug 20, 2008
Have signal, but no light, just one second screen can see and shut off.
Please clarify by shut off you mean power light turn off or just screen gone blank but power light remain on!
Mostly inverter(power supply) needs attention in such cases.
Feb 07, 2011 | Dell E198FP 19" LCD Monitor
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
Hi, I have a HP Persario CQ60 Laptop. W hen i switch it on, the power putton and wifi light up, the little power light turns on and i hear the CD rom drive for a couple of seconds but nothng else hhappens...
mines does the same but wen u here it start up an the screen goes blank take the battery out then it will say start windows normaly or safe and safe made networking click on safe mode networking and u can use your laptop again but with no sound hope this helped
Nov 18, 2010 | Compaq Presario CQ60-220US PC Laptop
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
My screen doesnt work.
I suggest you to perform these steps.
Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. I suggest you to connect the notebook to external monitor and check whether its working or not. Then please perform the harddrive self test also.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite A135 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
