Question about Maytag Microwave Ovens
MY Magtag microwave M439W0 made a loud popping noise and now will not heat food at all. The magtron may have failed. Is it worth the cost to repair it or should I replace it?
  • 4 Answers
You are right its magtron has failed. and the best thing is you should replace it.
Posted on Aug 20, 2008
Yesterday I started heating food in the microwave and immediately heard a loud popping noise. I stopped it to see if there was metal inside. which of course there wasn't any. It now won't heat and the...
There is an internal fuse but if you still have power on the display then likely the main transformer has failed and the cost to repair will likely exceed a replacement.
Aug 12, 2017 | Whirlpool GH7155XHS Microwave Oven
Makes loud hum noise but does heat
That is a symptom that the magnetron circuit has failed. It the part that generates the microwaves that heat the food. Not worth fixing since the replacement part can cost as much as as a new oven. Sorry.
May 24, 2011 | Whirlpool GH8155XJ Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
Feb 09, 2011 | Kenmore 62622 Microwave Oven
Started flashing and making popping noises, but still heated ok. Then stopprdheating and just makes a loud buzzing noise
The magnetron is most likely the problem, it heats the food and is the heart of the of the microwave oven, if it was followed by unusual odor more noticeable when you open the door that would confirm it, but that is not always the case. The cost to repair would exceed the cost of a new one
Jan 19, 2011 | Thermador MBBS Microwave Oven
There is a loud buzzing noise that happens when we try to use our microwave. It just started today. What could this be and how can we fix it?
the magnetron most likely has either failed or fixing to fail it is what heats the food while in operation...there is a high voltage transformer in the unit that sends power to the magnetron and heats your food while in operation is a common problem with microwaves the mag usually gets weak and will start to humm or buzz .... the problem with this is they are and can be costly around $100.00 for part and depending on your mechanically capability may be well worth getting a new one rather that tackling the repair yourself... good luck hope this helps please vote.
Jan 03, 2011 | Kenmore 63792 Microwave Oven
Everything appears to work. but the food does not heat up
The lack of heat would mean a failure in the magnetron circuit. It is the part that generates microwaves that heats the food. If it is making a loud buzzing noise when you operate the oven, it usually means that the magnetron has failed. It can cost as much as a new oven to repair, so it not worth fixing.
Oct 05, 2010 | Oster Microwave Ovens
Microwave oven: GE Spacemaker 1400 not heating. Model number JVM1430AB001. Need guidance on troubleshooting and repair of unit. Thanks!
If the oven is making a loud buzzing noise when you try to warm food and the food remains cold, it usually means that the magnetron has failed. Not usually worth fixing since the parts alone can cause as much as a new oven.
Oct 04, 2010 | GE Microwave Ovens
Heat element not working
Well, if there is not heating the food and making a loud buzzing or humming sound when it is on, then the magnetron has failed. It typically shorts out and fails. The magnetron for this cost $140 plus the cost of the service call, you're better off buying a new oven. Hope this helps.
Jul 07, 2010 | Frigidaire FMV156EM Microwave Oven
Microwave comes on but not heat item
It's most likely the magnetron that has failed if it does not heat the food. The magnetron is the part the generates the microwaves. When it fails, it typically shorts out, and makes a loud hum or buzzing noise. If this is the case, it is not worth fixing since the cost of the magnetron is almost as much as getting a new oven. Sorry.
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
