Question about Canon MV800i Mini DV Digital Camcorder
Camera will not load the tape, it ejects it immediately
Canon MV800 mini DV camera will no longer accept tapes
Apparantly an be caused by run (ideally off mains adaptor) for at least four hours and try again.
Another possibility is an unhooked or broken spring in the mechanism but don't tackle this unless your're good at that kind of work.
May also possibly be caused by head misalignment
Posted on Feb 17, 2011
Tengo una canon 800i vercion europea, el cual no puedo haceder en un sistema americano
Posted on Feb 19, 2009
  • del valle silverio Feb 19, 2009
    tengo problema con una canom 800i sistema europea, pero no se ves acolor en sistema americano
  • 763 Answers
If that is on warranty, send it back to the store where you bought it. they will repair that and do something with your camcorder.
Posted on Aug 20, 2008
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Canon camrecorder will not load cassettes take
Believe it or not, but I found a possible solution for that in another forum. The suggestion was, to let the camera drop from about 0,5 m height onto the floor. Make sure, that there is a carpet underneath, which prevents the camera from severe damage.
This is no joke - I have let it drop once and the cassette was loaded and everything worked fine. There might have been a sensor problem or a little hickup in the mechanic.
Try it on your own risk - but what do you have to loose ? I wanted to sell the camera as broken on ebay, but now, I have a running camera again.
May 15, 2010 | Canon MV800i Mini DV Digital Camcorder
Will not eject mini dv tape
I had the same problem. I cycled through the eject process until it finally gave me back my tape. I had to send it back to have the tape carriage replaced
May 03, 2010 | Canon Optura 20 Mini DV Digital Camcorder
Canon ZR200 -- I can no longer get the camera to accept a tape.
it could have been forced at some time and has bent the loading door,,, maybe a bit of cassette broke off inside it and is jamming it up best bet is to drop it off at the repair shop let them fix it for you,,
Oct 27, 2009 | Canon ZR200 Mini DV Digital Camcorder
I can no longer get the camera to accept a tape. It ejects the tape after I insert it. The tape housing never closes back into position like it should.
the camera just could have worn out, fixing this would be pretty hard.... but if you want to unscrew the screw and make sure all the connections are intact and find the tape head and wipe it off with clean gym shorts. then make sure all the gears are in the right place
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Canon MV800i Mini DV Digital Camcorder Logo
300 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
