Question about Sansui Televison & Video
Can not get dvd player pdv7012 to play - Sansui Televison & Video
  • 4,234 Answers
There are a couple of possibilities here. First try cleaning the lens using a cotton swab and alcohol. Then try both a music CD and a DVD. If the CD plays but the DVD does not, then it is likely that the optics are starting to fail and need to be replaced. I don't have a parts cost for Sansui players, but call around to determine if the replacement of the optics would be worth it.
Hope this helps,
Dan
Posted on Aug 20, 2008
    Genius:
  • 3,422 Answers
Did you try playing the different dvds to see if they play or not?
  • Priya darshan Aug 20, 2008
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. .
  • 6,487 Answers
Was this working before?? if yes did you try playing another disc and check if it play? if you cannot play any disc with this player there's a possibility that the lens is dirty or bad, you can try to run a CD cleaner to clean the lens..
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 20, 2008
    that can be a problem with the lens , it can be dirty so if you have a
    cd cleaner try running that , and check if you can now play a disc,,
    but if still not working after running a cleaner the lens can be bad
    already, if your player still under warranty replace it..
    Good luck.......
Does cyberhome ch-dvd 300 dvd player play burned mp4 movies?
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
Jun 18, 2010 | Cyberhome CH-DVD 300 DVD Player
Recorded dvd's wont play on other dvd players
some dvd players (outdated)..will not play these new dvd (recorded or pre-recorded dvd)...if you are recording dvd and wish to play on another dvd player (dvd player must be at least 2009)...same thing happen with my toshiba recorder...my jvc player works its (2008), but my sony dvd (2004) did not play any of the recorded dvds (only the store brought).....suggestion buy a not expensive dvd player (you just need it to play all that other features will push the price range up)
hope this help
May 30, 2010 | Funai PY90VG DVD Player/VCR
I can't play some DVD's on my Coby DVD player. The screen says WRONG DISC. Can I get it to play all DVD's?
only if makers have a firmware update for it.
some manufacturers dvd players will only play genuine dvd`s they will not play copies or they will only play +DVD`s not -DVD`s or DVD-+rw
Sep 03, 2009 | Coby TF-DVD7100 Portable DVD Player
My samsung dvd player will not play dvds, but it
Are you trying to playing recordable DVDs (DVD+R or DVD-R) ? if so, try playing original DVDs (the type you rent or buy) those are pressed DVDs - if it works, then your player does not support DVD-R or DVD+R - If you are using a computer burner that supports bitsetting you can change the booktype of a DVD+R to DVD-ROM to fool your player.
If however your player cannot play either DVD-R, DVD+R nor original DVDs and only plays CDs, then your dvd laser diode is finished - there is one for CD and one for DVD, this is rare but happens, there is nothing you can do, any repairs would be very expensive - you are better off getting a new DVD player they are very inexpensive now and any repairs will cost you multiple times a new DVD player.
Aug 25, 2009 | Samsung Televison & Video
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Does not play dvd copies
simple some actaully most portable dvd players just arent made to play copys or duplicates becaues they do not have the software for that kind of disc. so they instead can only play origanals dont worry my portable dvd player does this too
Apr 15, 2009 | Durabrand PDV-705 Portable DVD Player
DVD+R Wont Play in Mintek DVD 1600 Player
Kay what happens with some players is that they are only bulit to play a certain kind of disc. It also may be because the player is old. If you buy a new player it will be able to play all DVD's that you put in it.
Nov 21, 2008 | Mintek DVD-1600 DVD Player
I bought a DVD and I played it on my laptop. It worked on the laptop but when i put it into the DVD player it wouldn't play. So I tryed playing the DVD in the PC and it also worked on there. Again I...
DVD movies have region codes, and they typically only play on a player or DVD-ROM drive sold in the country where the DVD movie was sold.
The actual region code is in one byte on the DVD (digital versatile disc). The DVD player or drive has a region code in its firmware. Personal computer DVD-ROM players often have the code in the software or MPEG-2 decoder. The two codes must match for the player or drive to play the movie. The code is also printed on the back of a DVD package, superimposed on a small image of the globe.
DVD regional locking is used to control which DVD movies play in which countries or groups of countries. Movies are often released on different dates around the world. Region 1 has its own player that will only play Region 1 discs. Likewise, Region 2 players can only play Region 2 discs and not play any of Region 1's discs. The six codes are:
  1. United States and Canada
  2. Europe and Japan
  3. Southeast Asia
  4. Latin America and Australia
  5. Russia, rest of Asia and Africa
  6. China
please check the DVD region code again and what PLAYER u are using to play on PC / LAPTOP??
where did you buy the DVD player??
Jul 23, 2008 | Televison & Video
DVD player not reading dvd's
Check the link below to see how to clean the laser on a DVD player. If cleaning does no work, then the player will need servicing.
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Jerry G.
May 13, 2008 | GoVideo DV1030 DVD Player/VCR
Playing recordable dvd
Your player may only be able to play DVD-format discs. Try converting the video with Nero or WinAvi or DVDFlick to true DVD format.
Feb 21, 2008 | Emerson EWD7003 DVD Player
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
