Question about Singer CE-100 Futura Computerized Sewing Machine
Needle keeps hitting bobbin case on my Singer CE 100 Futura, it is now jammed completely. Why is this?
  • 89 Answers
Either your bobbin case isnt installed right or the machine's timing is messed up try to get needle loose or completly out is preferred then try turning it and see if it comes unjammed if so take your bobbin case out and reinstall it making sure it is in the fit right if this dont solve it then you need to get timing set (not recommended to do at home get pro to do it ) hope this helps you
Posted on Aug 20, 2008
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Bobbin case keeps popping out of my CE-100 Futura. Not sure whether or not the case is in there correctly.
Raise the needle to it's highest position and the case should go right into the shuttle.
Refer to the maintenance section of the manual for your machine.
If you do not have a manual, you can get one at the Brother website.
Apr 01, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
Bobbin case is a problem. Needle breaks, eats thread, now it is broken. I need a replacement. Where do I get one?
Sounds like in breaking the needle, you knocked the timing out, you probably scored the bobbin case too. Reset the timing if you can, and look for sharp edges on the bobbin case and needle plate. get rid if them with fine wet'n'dry paper
Mar 02, 2009 | Singer CE-100 Futura Computerized Sewing...
Needle brakes every time
If the needle is hitting the hook under your bobbin case, your machine is out of time. Unfortunately, unless you are familiar with this particular repair, you will need to take it to a qualified repair technician. You can however try a new needle and make sure that it is in properly. If the needle is not bent, then I am afraid you will need to take it in to be repaired.
Mar 01, 2009 | Singer CE-100 Futura Computerized Sewing...
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura ce-100(Singer)
Sounds like a tension problem. Email the singer company at talktous@singerco.com They should be able to help!
They responded back to me the same day.
Nov 17, 2008 | Singer CE-100 Futura Computerized Sewing...
Need Help putting the bobbin case back in the futura ce 100?????
With the needleplate removed, locate the black plastic bobbin case in horizontal and level position with the "bull horn" facing the rear, so the needle has space to move....
Gently place finger on top edge and move bobbin case, there ought to be a small amount of movement (1 or 2 mm slack) to allow passage of thread past the stopper spring (at front right)
If there is no slack at this position, have you adjusted anything to "tighten it up a bit", if so, relax the stopper spring by an "almost nothing" amount (again, 1 - 2 mm) to allow the thread to form the stitch.
....if you have had some needle strikes and damaged the surface, fine emery paper may be used to smooth the damage, if significantly scored, replace the bobbin case.
Feb 18, 2008 | Singer CE-100 Futura Computerized Sewing...
Problem with bobbin case - new machine Singer CE 100
My problem is solved (I think...that is a knock on wood kind of thing). Upon recommendation from another Futura user, I remove and clean my bobbin case and I put a drop of oil in the little hole under my bobbin case about every 5th or 6th monogram use. AND, I pitched all of my bobbins that were 15 and not 15J (I had some that were 15 and they were the culprit as well.) I have had no more problem. It seemed the least bit of lint caused me a lot of birdnesting. I also stopped using rayon thread and use only polyester and bobbin fill in the bobbin. I have got to say I am thoroughly enjoying my machine these days. Please try these things before giving up on this so user friendly machine.
Nov 22, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
315 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
