Question about Frigidaire GLTF2940ES Front Load Washer
Frigadare Dryer This front load dryer has a three prong cord. How can I adapt this to a four prong outlet. I can buy a four prong outlet. It has two hot wires one neutral and one ground. Adaption method please, if one exists!
  • 1,031 Answers
Basic Dryer Electrical
Electric dryers in the US operate on two 110 volt A/C circuits. The two 110 volt circuits combine to deliver 220 volts A/C to the dryer heater. Frigadare Dryer - 2-dryer-plugs.gifSee the basic dryer heat circuit. The dryer motor operates on 110volts A/C. Dryer receptacles have an L-shaped neutral post. You can check the voltage to your dryer by slightly sliding the cord out of the receptacle and using the leads from a multi meter to check for voltage on the blades of the cord that slide into the receptacle. Between the left and the right blades you should read 220 volts. Between the left or right blade to the center blade (the L-shaped blade) you should read 110 volts AC. The 4-post receptacle above has the L-shaped neutral and a seperate ground. It requires a 4 wire cord and the ground wire is isolated from the neutral on the dryer.
Technicians check for voltage when the dryer is attempting to start or not heating for a very specific reason. Checking for voltage without the dryer plugged in does not tell the full story. A dryer heater uses 220 Volts and draws about 20 amps when it is heating. Checking for voltage from L1 to L 2 on a defective circuit may show 220 volts but when the heater kicks in and starts to draw 20 amps the voltage may drop off to 0 volts. Imagine the wiring to your dryer was stranded wire. Stranded wire is composed of a number of small-gauge wires bundled together to make a larger wire. What if all but one of those stands were cut and only one small wire was completing the circuit? Reading voltage at the receptacle without the dryer plugged in you would read 220 volts from L 1 to L 2. However with the dryer plugged in and the heater attempting to draw a heavy current, the electrons (current flow) would be dammed up behind the cut and only a small amount of current would pass through the wire. Certainly not enough to make the heater heat. There are a lot of things that can cause a partial circuit but the result is the same as the stranded wire example. Many a heater or dryer motor has been changed needlessly because of a loose connection in the fuse box / circuit panel or some other dryer electrical circuit problem.
Posted on Aug 20, 2008
  • Starnley Johnwells
    Starnley Johnwells Aug 20, 2008
    . convert the dryer cord so that its plug is 3 prong. That way, it will fit into your 3 prong outlet.
    For this you need a 10/3 cord specifically labeled as a dryer cord. The "10" refers to the wire gauge, and the 3 refers to the number of individual wires within the cord.
    How to Convert Dryer Cord from 4 Prong into 3 Prong
    • Remove safety plate (usually attached only by 1 or 2 screws)
    • Remove old cord and restraint with a hand or cordless drill. I find that I tend to strip these softer screws with the cordless drill, and they are short enough that they can be easily unscrewed by hand. The restraint is the collar that fits tightly around the cord to hold it firm to the dryer.
    • Connect the center wire of the 10/3 cord to the center silver terminal. Turn screw in firmly but not too tight.
    • Now you have two wires remaining which are attached on either of the two terminals beside the silver terminal. It does not matter which wire goes on which terminal, as both wires are hot. Screw in firmly.
    • The hardest part is always the restraint collar. From the outside of the dryer, you need to slide the tab end of one of the collar halves into the 10/3 cord wire hole. Do the same with the other half of the collar, except on the other side of the hold. The two screws will, theoretically, easily draw the two halves together to tighten against the cord. However, the two halves of the collar never seem to be parallel, and it takes quite a bit of effort to get the screws to catch. As long as even the tips of the screws have "caught," you're good to go: turn the screws and they will slowly draw the halves together, even if the halves are not really parallel.
    • Replace safety plate
    on the three prong unit the bottom plug will accept the neutral (white wire), the top two plugs will accept a black and red(color can vary but NEVER WHITE OR BARE COPPER). It doesn't matter which is which. The slots will most likely be labeled by each screw head as neutral or white; black, red, or line. Just follow the labels. On a four prong outlet you will still have the two hot leads(red and black), a neutral(white), and also a ground this screw will likely be green it accepts a naked wire or a green insulated wire. Maybe your best bet is to just buy a new outlet (4 prongs for four wires three prongs for three wires) as the box will have instructions on it and the outlet will still be clearly labeled.
  • Frigidaire Master
  • 19,396 Answers
If you have a 3 prongs Appliance and you need to connect it to a four prongs US socket.
If this is correct you solve the problem by buying an adapter cable like this one here for $25 (click here to open).
Much better than removing and replacing the plug, as yo do not risk shorts from bad plug fitting.
You can also buy a similar product fro a local electricals' shop or from Circuit City, the smaller adapter costs about $10, $25 one is safer.
Let me know if you need more help.
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
I have recently got second hand WHIRLPOOL LER4634JQ0 ELECTRIC DRYER, however haven't got power cable and Hose pipe. Can you please guide me which powercable and hose pipe to take ? where I can find...
look at the outlet that you'll be plugging it into,if it has three openings get a three prong cord if it has four holes in it then you need to buy a four prong cord,you can buy vent line at any store,if there's a home depot near you go there and get everything you need.good luck with your new machine.
May 15, 2011 | Whirlpool LER4634J Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
Our dryer has a four plug power cord and the wall socket has only three. Can this be adjusted any way?
Yes buy a three prong dryer cord and replace the four prong cord.The terminal block should be 3 terminal ground in center.
Jun 18, 2009 | Whirlpool Dryers
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Feb 19, 2008 | Frigidaire FEQ332E Electric Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
115 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
