Question about DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker
Tried to remove infuser, must have done it with power on.cant get infuser to come out now it a delonghi magnifica
  • 2 more comments
  • w0teva Oct 25, 2008
    our infuser got caught in down position when we were trying to fix it, now we cant get it out and no one seems to know how to help us. they suggested sending it to a repair shop, but we called and they wont tell us how much. how can we get it out??? help
  • Anonymous Mar 19, 2014
    where is the delonghi en670 infuser
  • Anonymous Mar 23, 2014
    The diffuser is stuck at the upper level.generic red warning ligtj is on and so are the two green lights without blinking. I live in Uruguay and no service center in the country. What do I do
  • Anonymous Apr 01, 2014
    infuser stuck
    Master:
  • 848 Answers
Can you provide more details about your problem ........... is your problem to remove infuser ??
Posted on Aug 20, 2008
  • DeLonghi Master
  • 19,396 Answers
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
  • 6,487 Answers
Removing the infuser while the unit is ON will definitely cause a damage , that's why now you cannot take it out because there's already something wrong happen with the infuser already and you may need to dismantle the unit and remove the infuser that way..
Hope that helps.....
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica door comes open after grind and just before brew?
try changing the defusser..... bsc appliances 07779933829 postal service too.
Feb 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
When i go to clean the infuser it will not come out
Have you turned your machine off? You can not remove the infuser if the machine is still turned on, and if you try you will probably damage your machine.
Jul 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Impossible to remove infuser, appears to be jammed
Plug in Machine. Turn on for 10 seconds or so. Turn off. Let Machine turn itself off completely. Once it is quiet, do not unplug, try to remove the infuser. It worked for me (procedure recommended by customer service for Delonghi in Switzerland).
Oct 23, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser will not come out, can anyone help?
the infuser is tilted and I cannot get it back to center
Jul 20, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker Logo
1,577 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
