Question about Philips Televison & Video
Philips 32PW9617 - smoke coming out of the back. Looked at by local repairer who says he can't do it, even if he knew what it was. TV now in service/ mode.
Tried another repairer - Philips specialist. Fixed and returned by the next day. Reasonable cost and excellent service. YTV Repairs Burley Road, Leeds. Even got the two replaced ceramic filter capacitors back! Can you suggest what I can do with them?
Posted on Aug 24, 2008
What is the code i need for my philips universal remote to work on my veon tv
Your remote should come with a complete list of product codes.......if lost, try phoning your local Philips repair shop.
Even an unauthorised repair shop will sometimes have all the codes.
May 04, 2014 | Computers & Internet
Philips tv smokes
Do this only if you are a qualified service technician:
This problem can come if any moisture has entered or is formed inside the TV.
Switch of the power outlet, and remove the plug. Open the back cover and check what are the parts burnt visibly. If it is in the SMPS area, you may require a thorough check on the load and replace all the burnt parts by looking through a Service Manual. Anyhow, this might require attention by a qualified service technician.
Jul 11, 2012 | Philips 47PFL5603D/27 Flat Widescreen TV...
My 19pr15 c122 will come on for a second then shut back off just wondering if its something fixable or should i just trash it
It's seldom the parts that cost much, it's the labor to figure out which parts are causing the trouble that make TV repairs expensive. Many things can cause a TV to behave the way you describe, so I can't point out one or two specific parts. Even if I knew exactly what was causing the problem, you might have trouble getting the parts or lack the tools and soldering skills to replace them. It's possible to do more damage trying to repair a set without some experience. So while it's certainly fixable, it's probably not economical for this small of a TV. You could easily replace it for the same cost you'd likely face if you have a technician service it. Use this as an excuse to find yourself a new TV.
Jan 01, 2011 | Philips 19PR19 19" TV
Philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Mar 26, 2010 | Televison & Video
Good evening I have a philips 42 plasma and as it warms up I loose the bottom half of my sceen and it comes back when I tap gently on the dise. Usely not happening after it's warmed up
Good day sir, there is a probability that a loose component inside your TV is the culprit, and as you tap it gently on its side it makes contact again, the part is usually (probably) located at the Vertical stage of the TV, you can't do anything at this point but to call your local service repair man, they will look for the loose part, resolder it and test. It seem simple but it takes a lot of time to find the loose part. hope this helps.
Oct 12, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Remote is not working with tv
You probably have a defective IR receiver in the set, have it looked at by your local service company.
Jul 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My tv 32pw9617 switches of by itself.
sounds lick you may have a dry joint in the powers or line o/p stage.
as a rare fault it could be the crt with an intermittant internal s/c. but you would notice the colour was tinted either red, green, or blue in the dark areas of the pic.
Jul 13, 2009 | Televison & Video
TV will no longer turn on
Your power supply or interface circuit needs servicing.
Jul 10, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips tv 32pw9617 wont turn on red led flashes , looks like in protection mode , any help be good , thanks .
I had this on this model a year ago
Your power supply has blown
I had to courier it off to the Phillips service centre to have it replaced, they got it back to me the next day (this was in Sydney)
Hope this helps
May 10, 2009 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
