Question about Gateway Computers & Internet
I have a EMachine Computer that has 512 MB and I want to changes this DRAM to 2GBs. I have purchased the two 1GB memory items from Tiger Direct and I need information on how and where to install them. Is it safe to remove the 512MB and then install them. I need a skematic on where they are to be installed.
    Novelist:
  • 210 Answers
No, you've got it in one.
I think you'd only have two memory slots anyway.. so shut down, unplug the power, then remove the existing memory. Push the white tabs that are on either end of the memory out and down until the memory pops loose. Remove it, then install the new memory the same way around.
I'm not sure if your motherboard can support 2gb of RAM, but in any case, that is the correct procedure for upgrading memory.
Posted on Aug 20, 2008
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I recently received and old Systemax Tiger computer. It has Windows XP on it and has 256 MB of DDR SDRAM on it. Now, i also have an old Dell computer that has 512 MB of SDRAM in it. Will my Systemax...
No, you will have to use DDR memory only. Fortuately, DDR id VERY inexpensive now.
I can recommend www.TigerDirect.com
They are a very low priced but reputable company. This is a current item, with price.
Corsair Value Select 512MB PC2700 DDR 333MHz Memory $17.99ea
Good luck
May 27, 2011 | Computers & Internet
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I am trying to expand memory by inserting 2 PC3200 (DDR400) but total amont of memory size does not changed (still 512 MB) First slot (DDR1) APACER-512 MB Second slot (DDR2) LG Electronics - 1GB
Take the stick of 512 out of the motherboard and insert the 1GB stick in DIMM 1 slot and switch the machine on. If it comes on check whether it has registered it as 1GB. If it has turn the machine off and just put in the 512 stick.
If the machine won't boot up with the 1GB stick then it could be faulty or the motherboard doesn't support 400MHz (which it should).
Regards.
Oct 20, 2010 | Asrock 775VM800 Motherboard
I need to buy memory for my computer its an emachines desktop model# T3410 512 MB DDR SDRAM and I dont know what to get
in DDR ram there is some models like ddr and ddr2 and another new model is DDR3. First you check what is your ram related to. for that in some pcs bios option system information the details are there. For that at the time of booting before windows logo press the button whatever is showing to enter setup. and check otherwise remove your ram and take that to a computer shop and take a new ram with same model.
And one more thing is you have to check your clock speed of your ram. Remove your ram from pc and check if any information is there on ram
Jun 24, 2010 | E-Machines eMachines Desktop PC
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Computers & Internet Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
