Question about Sharp Office Equipment & Supplies
Sharp SF-2014 Copier Jams
The copier copies OK but the paper stops 3/4 of the way out the exit. And then the jam light comes on. I have changed papers no luck. What is the problem.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Posted on Aug 20, 2008
6ya staff
SOURCE:
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Paper lifts on clp 315 and then stops halfway and flashes paper jam light but nothing seems to be jammed paper ok any ideas
This is the problem in the exit sensor of the printer. Please approach authorised service center they will change for you.
Oct 20, 2009 | Samsung CLP 315 Laser Printer
Canon Image Runner C2058: Paper keeps being jammed at the same location. It happens at the last exit of the copier. When I clear the jammed paper, the image is printed on the paper. It simply could not...
Two ways. The First, you should consider the condition of the sensor of the output block. He can be conks or falls out, sticks. Possible correct the tweezers, however better apply to service. If he faulty, follows its change. Can try.
Jun 29, 2009 | Canon Office Equipment & Supplies
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Sharp-275 Not a simple paper jam
This sounds like you may have a bad jam detect sensor, there is a sensor on the exit end of the fuser on the right and the flag for this is located in the middle of the exit guide on the fuser this gives us most of those types of jams.
Hope that helps...
Jun 16, 2008 | Sharp AR-275 Copier
Red light on Printer doesn't want to print anymore
pull out the cartridge and look for paper inside, re-install cartridge, also look on the back part where the fuser and exit assembly is look for paper jammed. also make sure the paper is set correctly on the tray.
Jan 06, 2008 | Brother HL 1430 Laser Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Repeated paper jam in the fuser unit
you can try this solution , the lower right door at its front and rear have smal piece of rubber this piece needs to change by another one have large thikness.
Jul 25, 2006 | Canon imageRUNNER 4570 Copier
122 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
