Question about HP Computers & Internet
How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
How to connect power led ,HDD,Reset,power SW cables in hp motherboard 383620-001
  • 34 Answers
Check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Posted on Aug 20, 2008
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
Please I need a picture or pictures of how you connect the cables from the cabinet in this motherboard GA-G31M-ES2L. the office that I'm trying to enjoy the positive it has entered a msg on the board and...
> HDD LED == hard-disk drive Light Emitting Diode (a "lamp" that lights-up when you are reading/writing files to/from your disk-drive)
> RST SW == the (optional) "reset" switch/button on the face-plate
> SPK == the internal PC loudspeaker
> PW SW == the power on/off switch/button on the face-plate
First, connect the "PWR SW", so that the ON/OFF button works.
It's much less important that the other wires be connected.
For example, if you never press the RESET button on the face-plate, you don't need to connect that button to the motherboard.
Oct 22, 2010 | Gigabyte GA-G31M-ES2L Motherboard
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Don't know which pins to connect the power sw cable to.
Here is the Layout and installation of your board. Hope this helps.
http://www.bcmcom.com/tech/SL620/SL620-manual.PDF
Jan 29, 2009 | NEC PGA370 SIS620 ATX Motherboard...
Want to connect my mercury PVM7 PRO MB
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
Jul 28, 2008 | Computers & Internet
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Computers & Internet Logo
2,391 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
