Manual needed for Hp 383620-001 XW4300 System board
I need a manual for Hp system board 383620-001,
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
You will find everything in this link
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=471922&docIndexId=64255&manualLang=en
Please rate this post as solved.
Do not hesitate to ask another question.
Thank you
Posted on Aug 20, 2008
No operating system installed yet on HP xw4300 and it's booting to a black screen...problems getting it to boot from CD. I am in Parted Magic currently.
have you changed anything in BIOS.?how man drives do you got 1 or 2 ?.are you sure windows are on the drive you try to boot from.if you have set optimal defaults.BIOS can change drives.of your desciption i think you got 2 drives.can you get into BIOS try F8 OR DEL.should think DEL .if 2drives change drive.
Apr 03, 2013 | E-Machines T4060 PC Desktop
I used a hp restore plus cd on my hp xw4300 workstation and i dont have the second disk it is asking for.i need to restore my tower .all i can get into is hewlett-packard setup utility..is their a way i...
A HP restore CD is unique to each model HP computer, You cannot us a HP restore CD on any computer.
You need to get the correct HP restore CD for your model HP computer from the HP WEB site.
Dec 01, 2012 | Computers & Internet
Will xw4300 accept compaq S6200cl hard drive
HP XW4300 Workstation Desktop PC specs,
http://h18000.www1.hp.com/products/quickspecs/12260_na/12260_na.HTML
Scroll down to you come to the bold heading -
Standard Features - Specs
Go down the chart on the left side until you come to -
Interfaces Supported
1 SATA 3Gb/s interface (4 Serial-ATA connectors), 1 EIDE interface for optical drives
One EIDE interface. That is the Blue 40-pin connector, on the right side of the Ram Memory slots. (39-pin actually)
(Right next to the Black Floppy Drive 34-pin connector, and above the 4 SATA connectors)
Compaq Presario S6200cl Desktop PC >Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=390423
Product Information > Product Specifications > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00056951&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=390423
Scroll down to the bold heading -
Hard drive
120GB Ultra DMA
It is an EIDE harddrive.
http://en.wikipedia.org/wiki/Parallel_ATA
HP XW4300 Workstation motherboard example,
http://www.ebay.com/itm/HP-XW4200-XW620-DDR2-MOTHERBOARD-358701-001-SOCKET-775-/110904128317?pt=Motherboards&hash=item19d266b33d
The answer is Yes.
Connect just the EIDE harddrive from the Compaq.
Make sure the correct jumper pins on the back of the harddrive, have a jumper cap on them to set them to Single;
OR,
The IDE harddrive model you have may Not use a jumper cap on any jumper pins, for some models of harddrives, to set the harddrive as Single.
Look up the harddrive jumper settings on the internet.
Start with the model number on the label of the harddrive.
Example; WD2500JB
Western Digital 250GB harddrive that is IDE. (EIDE)
Western Digital jumper settings for IDE (EIDE) harddrives,
http://wdc.custhelp.com/app/answers/detail/a_id/463/c/123/session/L3RpbWUvMTM1MjE4NDY3Ni9zaWQvQnoxcVF6YWw%3D
You will need a SATA optical drive now.
BIOS Setup > Boot Options > Set the first boot device to CDROM.
Install Windows disk.
Use IDE harddrive, and IDE optical drive on the same flat ribbon IDE cable?
Can be done, but usually is a HEADACHE, and MAY not work.
BIOS looks to see what drives are connected. It looks for the drive with the Operating System on it. (Windows)
Now put a disk in the optical drive. Time has to be divided between the harddrive, and the optical drive.
IF it does work; when you are using the computer, and the optical drive you will know the real meaning of Slow.
Have a SATA optical drive?
Regards,
joecoolvette
Nov 05, 2012 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Good afternoon. re: HP xw4300. The microphone socket on the front panel has a cable that ends in a connector which is not attached to anything. The connector has 12 connections, but I can find...
Hi Tony,
Its the Audio Connector. and it is supposed to be connected at the position marked as 1.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 17, 2011 | HP xw4300 PC Desktop
I have a seagate barrracuda hard drive model ST3160023A which came out of a working bootable Compaq Presario 6000. I would like to use this hard drive in a newer workstation HP xw4300. I being told this...
i have not heard of anything like that. the only thing that would make a difference is the connection. yours is sata i believe. here is a link that tells everything about that drive.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Ultra_ATA_160_GB&vgnextoid=cd5cb1774aafd010VgnVCM100000dd04090aRCRD#tTabContentSupport
i do believe you would have to wipe the drive and format it and treat it like a brand new drive when you install it.
Feb 06, 2011 | Seagate Internal Hard Drives: ST3160023A...
I am replacing one drive in my Raid setup it is Raid 1 I have an HP xw4300. How do I rebuild the raid
Raid is supposed to self replicate, and you can hot swap drives when one fails, and the information is moved to the new drive..
Nov 03, 2010 | HP xw4300 PC Desktop
Need to replace the battery on my HP Compaq
it has system board /mother board in your system unite which called processor board replace it carefully and insert new one same type 3 volt
Nov 21, 2009 | HP Compaq dc7600 PC Desktop
XW4300 Sound Card problem, only working in Windows MP
Most online audio makes use of Adobe Flash, did you check that?
Best is to download and install the latest version of Flash to make sure.
Installing the latest version of DirectX for Windows XP can also help (9.0c).
Please also check for further suggestions about fixing sound problems in Windows XP.
Apr 01, 2009 | HP Workstation xw4300 Pentium-4 650 3.4GHz...
Digital audio out in XW4300
Right, it uses a fiber optic cable that connects to the "Digital Out" on your computer. There is "harmonic distortion" with the use of the RCA cables; the louder the output volume the greater the distortion. When using the "Digital Audio Cable" the is only pure data signal, aka DSP (Digital Signal Processing), because the two devices communicate with Infrared light flashes through the fiber optic cable; trust me you can hear the difference. You may need to buy one of those cables if your receiver did not come with one.
Nov 30, 2008 | Computers & Internet
SYSTEM BOARD for HP Compaq Presario V2000 PC Notebook
HP are very good at supplying service manuals. However the one I have specifies part nos for Pentium M (373522-001)and Celeron M (373523-001)CPUs on the V2000
Sep 07, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
1,316 people viewed this question
David Payne
David Payne
