Question about Nintendo Wii Console
Wii remote The wii only appears to be registering some movements from the wii remote but not all of them?
  • 344 Answers
Hello.
You need to make sure the Wii knows where the sensor bar is. (Above or below TV) Another cause is low batteries. Also waving the Wiimote out of range. Make sure the sensor bar is on the very edge of your TV stand, or enterrtainment center. I have noticed on mine that if I'm going crazy with the wiimote and go to low, it will not register. Those are the most common problems and solutions. But you may even have a bad wiimote. There is also a calibration setting for the wiimote. So try all that. I hope this helps!
Good luck and happy gaming!!
Posted on Aug 20, 2008
  • 32 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 05, 2009
2 Suggested Answers
SOURCE: My remote won't register movement when I shake it
I spoke to customer support who told me to lie romote on its side on a worktop and tap it on the top 4 times - same on the other side and it worked !!! not very technical but apparently the motion sensors get stuck and this releases it!
Posted on Feb 15, 2010
Player 2's remote won't work when the dancing starts, but it will work for everything else. Player 2's motions are not being registered and won't count for points. Then the player 2 disappears (because it...
We had the same problem: IF YOU OPEN THE BACK COVER ON YOUR WII REMOTE THERE IS GOING TO BE a red button and some where on the WII too so you press that at the same time and your done
Dec 26, 2010 | Ubi Soft Just Dance 2 for Nintendo Wii
My wii remote movements appear to be delayed
Make sure the controllers are fully charged and don't stand too far away from the reciever and make sure its not blocked by anything, also clean the receiver just in case its dusty, and restart the Wii too.
Regards.
Jun 30, 2010 | Nintendo Wii Console
My remote won't register movement when I shake it and I've tried resetting it, changing the batteries, re-sycronizing etc. but it still won't register movement when I do something such as jogging. I also...
Jan 17, 2010 | Nintendo Wii Console
Can't register my second or third remote. my remotes register with wii sport no problem
you need to schronized take your remote and where the batterys go press the red button then really fast where the sd card goes there is a onther button press it.
Dec 28, 2009 | Nintendo Mario Kart (Wii) for Wii
Wii big beach sports mulitplayer problem
ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2
Apr 03, 2009 | Nintendo Wii Remote Controller
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
Mario cart will not recognize my second remote.
Another possibility is that the original poster did not push the "+" button on the main remote when on the screen in Mario Kart to register additional remotes.
This happened to me. I was holding down the 1 and 2 buttons over and over on the second remote, watching the blue lights flash, but the remote wouldn't register. Eventually someone noticed the instructions on the screen to push the "+" button. When you push the "+" button, another screen appears to let you really register additional remotes.
In Wii Sports, there is no pushing of the "+" button to register new remotes... I had incorrectly assumed it worked the same way in Mario Kart and didn't bother reading the on-screen instructions.
Dec 24, 2008 | Nintendo Mario Kart (Wii) for Wii
Wii remote
Aug 08, 2008 | Nintendo Wii Console
Wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
Jun 21, 2008 | Nintendo Wii Console
Nintendo wii
First of all, do you have a sensor? If you don't you should get one because you can ONLY make movements with a sensor. If you do put the sensor in a place that you'll be pointing your Wii remote at. Example: Try putting the sensor on top of a short television. Always try to point at the television because the sensor can detect the Wii remote. Hope that helps!
Apr 21, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
96 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
