Question about Nokia 6600
Phone Setup Failed
Sir,
While Hard core formatting on the process, i removed the battery then the message appeared:"phone setup failed, contact the retailer"
    Problem Solver:
  • 30 Answers
Format and install a new software again. you'll get it..... dont forget to rate the post
Posted on Aug 20, 2008
Fourmat usear seting are hold * 3 send kea and on you phone
Nokia 6600 phone startup failed. contact the retailer how to remove
it is a software problem try hard reset by pressing * 3 send green button and then power on, phone will show formatting , put a fully charged battery before doing this.
your phone will be fixed, data might be lost already.
Dec 22, 2010 | Nokia 6600
When I try to open my text messages I get the following message- message notification Message delivery failed. or message receipt failed. Next to the battery level indicator in the upper right hand...
The messaging system of your phone may have become corrupted, If you have already tried a hard reset by removing the battery from your phone while it is powered on I would contact your service provider. A factory reset may be necessary, or they may need to reconfigure your text messaging set up.
Rylan
Dec 16, 2010 | HTC Ozone XV6175 Cell Phone
Help please! My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the...
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Mar 29, 2010 | Nokia 3230 Cellular Phone
Phone start up failed please contact your retailer
try to do hard formatting to restore to factory settings, here's you need to do.. 1.  switch off your phone 2.  remove sim and memory card.. 3.  press buttons 3, call key and *  at the same time and switch on your phone without releasing the 3 buttons until you see nokia logo and hard formatting message.
good luck.
Mar 11, 2010 | Nokia N76 Cellular Phone
Phone start failed contact retailer
sir i have c7 nokia when it on a message shown. phone start-up failed.contact the retailer.plese help me what i do
Apr 24, 2009 | Nokia 6681 Cellular Phone
Need to formatting nokia 6260 mobile
Hello sir,
I got the same startup failed problem. Did u get any solution. Please let me know how to resolve this issue. my id is surenar.malreddy@gmail.com
Thanks.
Mar 23, 2009 | Nokia 6260 Cellular Phone
Nokia n72 phone startup failed contact retailer
FORMAT YOUR HANDPHONE. TURN OFF YOU HANDPHONE, THEN PRESS CALL, 3, AND STAR THEN PRESS ON KEY. YOUR HANDPHONE WILL BE FULL FORMATTING.
Jan 22, 2009 | Nokia N72 Cellular Phone
Mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
Jan 13, 2009 | Nokia 6600
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
Sep 09, 2007 | Nokia 3230
Nokia 6600 Logo
142 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
