C++ connect to oracle
How c++ connect to oracle?Please give a source code.
Orcale problem ?
This is an Error generated by the Oracle Client when the Oracle Server can not be reached.
This error can be caused by several items:
The Listener on the Oracle Server is not running. Check with an Oracle Administrator
The Oracle Server is off line. Check with an Oracle Administrator
The network connection to the Oracle server is not fully up and running. Check all connection points between the Notes server and the Oracle Server
A firewall exists between the Notes Server and the Oracle Server, and is not configured to allow access to both the Oracle Server's IP address and Port
The ADDRESS Parameter in the TNSNAMES.ORA file is incorrect. Use TNSPING (or TNSPING80 on Oracle 8.0.x) to check the connection to the Oracle Server. Example of a successful connection:
D:\ORANT\BIN>tnsping80 oracle
TNS Ping Utility for 32-bit Windows: Version 8.0.5.0.0 - Production on 23-APR-99
10:24:39
Attempting to contact (ADDRESS=(PROTOCOL=TCP)(HOST=DBSERVER)(PORT=1521))
OK (50 msec)
If this is Not successful, check your Oracle Network Products Messages Manual to resolve the errors that TNSPING points out.
well i found this from one site .... hope u can read it and can solve your problem
Oct 14, 2009 | Computers & Internet
How to retrieve database of ORACLE using c sharp code
You will need either Orcale data provider or ODBC driver. Once either one of the above is setup, you can access your Oracle database using ADO calls. Please refer to this site for more info: http://www.csharp-station.com/Tutorials/AdoDotNet/Lesson01.aspx
Sep 21, 2009 | Oracle Database 10g
Strtdb80.exe
First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Servic es\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Regards,
Mar 27, 2009 | Microsoft Windows XP Professional SP2
Vb 6.0 to oracle connectivity problem
Your SQL query does not look valid. Test the query in SQL Query analyzer, and then once it is working, copy it into your VB source. You will of course then need to make the query a string that VB will accept.
Mar 23, 2009 | Microsoft Computers & Internet
I can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
How to develop a tool for conversion the database from sybase to sqlserver
ahh..sudeep...it is a truly glorious day for this work. The detailed solution is to call Larry Ellison, at Oracle, and enquire if you can have his code.
Apr 23, 2008 | Computers & Internet
Can we install Server component in Vista Home Basics
I see no reason why you cannot do so. Just make sure you find all the drivers for you laptop before you migrate.
Apr 18, 2008 | Microsoft Windows Vista Ultimate Edition
Connection of Oracle9i with Visual Basic 6
if oracle scott
password tiger
if not acccepted go to control panel ,administrative services put
oracle services manually & start it.
ur's kishore chowdary.(+919441133420)
Mar 28, 2008 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
