I cannot get the 'Auto' option to work on the TUC-1 media take up roller (the printer is a Roland SJ745-EX Dye sub) and keep having having to uyse the manual switch. The print i am am doing will take a good couple of hours and i need to get the auto function working. What could b the problem? Thanks, Alex
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm..I'd be reluctant to suggest that leaving a printer unattended for that long is a good idea.
Posted on Aug 20, 2008
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Paper Jam error
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure thatyou have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
May 17, 2008 | Olympus P-440 Thermal Photo Printer
Olympus P 400 driver mac 10.84
Olympus has not supported that printer on the Mac in 10+ years. Also checking the Apple printer driver support page I do not see ANY Olympus printers currently supported by Apple: OS Printer and scanner software available for download
I would suggest replacing that printer with a current model photo printer (also Dye-Sub) from Canon. The Canon Selphy Dye-Sub photo printers produce flawless professional glossy prints: Compact Photo Printers
Dec 05, 2013 | Olympus P 400 Thermal Printer
I have roland verscamm 540v when i sub switch on
hello m f azam
have u solve the problem already?
Aug 20, 2013 | Roland VersaCAMM SP-540V
Roland fj-500 yellow dye ink printhead not printing
i have printer sj 160 st jet pro,problem in unrecovrable limit.and affiche ecran st jet pro sj???
Aug 02, 2012 | Roland Printhead FOR FJ-400 / FJ-500 /...
I have a Roland SP-540V printer and I keep getting pinch roller errors. I have cleaned the iris/sensors, hard restart, rebooted my system. Still is not recognizing the print media. I printed yesterday no...
hi have had the same problem, you need to clean the data strip that is connected to the main cutting head .its a clear looking plastic strip between 2 other strips you can't pull it all the way out so be careful. just wipe it with a clean cloth you will see black soot like powder come off it, as soon as you do this it should be back to normal, repeat weekly and you should be ok.
Feb 25, 2010 | Office Equipment & Supplies
How do I print using the foil ribbons? I do not see Gold foil as a color choice.I am interested in any info from a manual on this subject of gold or silver foil ribbon printing.
Your ALPS MD-5000 MUST be set to print in DYE-SUB. mode.... Is there a Memory upgrade plugged into the slot next to the Printer Port? If not, then it's not an option......
Feb 11, 2010 | Alps MD 5000 Thermal Printer
Vista drivers
The XP driver works with Vista
Feb 08, 2008 | Kodak Professional 8500 Thermal Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Mis-register
Hi There, 1. Make sure there is no dye film stuck to the print roller. This will cause card mis-registration (you will see feathered edges or a blurry effect. If there is dye film stuck to the print roller peel it off using adhesive tape or similar (the dye film will stick to the tape). You can move the print roller round with your finger quite easily. Then clean with a normal cleaning card. Afterwards check your print start and end position (you may be printing off the end of the card - also snaps the ribbon often!) 2. Make sure the other pinch rollers are really clean. 3. ** Check the warranty status first! *** Remove the right-hand side panel (2 screws on the side, 3 at the back). Check for free play on the card transport stepper motor pulley (there should be none!). Check the belt tension is not too loose (motor is adjustable - loosen 4 screws)). Hold the print roller with your left hand while trying to turn the large plastic pulley. You should feel no play. The grub screw on the pulley can sometimes come loose (1.5mm hex key required). Do NOT try to use a ball ended hex key. This only rounds off the grub screw socket. I hope the above helps! Regards, MC.
Oct 19, 2006 | Magicard Tango 2 Printer
47 people viewed this question
k24674
jasbo
jasbo
