SOURCE: I am looking for an exhaust hose kit for Amcor portable air condi
While you may find a kit specific for your portable air conditioner, it would be far easier and faster to simply measure the diameter across the exhaust port on the back of the unit. In US measurement, it may be 4 inch or 5 inch across.
Go to a hardware store (a quaint local one or a Home Depot if you must.) They will have a kit (for clothes dryers) that will most likely include the flexible tubing and two clamps. They also will have separate/bulk flexible tubing and clamps available.
Depending on how permanent the air conditioner installation is, the same hardware store will have exhaust outlets that can go through the wall and probably fit into a partially opened window.
Please post back here with further questions or clarifications on your problem.
Good Luck!
SOURCE: Parts for Fedders Portable Air conditioner model # SFPEB08F2A
there are two separate solid plastic pieces between the hose and the body of the unit
i have a hose but I am about to donate the unit
SOURCE: problem with rooftop air conditioner duo therm brisk air box kit
Try having a professional check that the collant lines have not perished. Also have them check the thermostat and that there is actually gas in the system. The warm air suggests that the unit has no gas.
SOURCE: Amcor 12000-E air conditioner will
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
