Question about Microsoft Office Professional 2007 Full Version for PC
Career i did complete ba in 2008. with eco, geo & englit. i have no intrest in geo but i got good marks in this sub. i like eco but get avg mark in it. what should i do. i am also a computer teacher. what can i do after ba in condition? please suggest me. i m waiting
    Problem Solver:
  • 30 Answers
U can do ur masters in eco. Simultaneously u can do any computer certification course like oracle or sun java as u said u r a computer teacher.
plz do comment on this suggestion and dont forget to rate it.
Posted on Aug 20, 2008
Ichanged the head on my 91 geo storm 1.6 dohc and now it won't start
Double check crankshaft timing mark, on your lower timing cover has some timing marks - crankshaft should be on the 0 mark. Camshaft timing marks--intake camshaft mark set at 3 o'clock and exhaust camshaft mark set a 9 o'clock. These timing marks are critical for motor to run and start correctly. These timings marks can move while trying to install the timing belt. After, you confirm or reset timing and belt, you can confirm timing is correct by rotating the crankshaft twice. Your timing marks should be on right on timing marks discussed at the top of the page. If timing marks are off, start over with timing process.
Jul 11, 2012 | 1990 Geo Storm
My GE Mod #JBP65GS1AD oven recently started acting up. The bake element had a small glowing area 1/4" long even with the oven turned off. We used it a few times, shutting off the power in between...
The way it can be tested is access the back panel so you can get to the oven control(its the clock asm) find a wire terminal on the clock marked as BA for bake and use a volt meter and see if 120 vac is coming from that terminal when the oven is off. The wire must be removed from that terminal so you not getting back feed and has isolated the test just to that. IF it has 120 vac or actually and voltage higher than about 5 vac when the oven is supposed to off the relay board (aka clock) is bad. UNPLUG OR TURN OFF BREAKER TILL WIRE IS OFF OF BA AND READY TO TEST then restore power make sure its marked as BA their is another marked BR thats for the broil element.
Good luck, i hope this helps
Aug 01, 2011 | GE Ovens
I have a 1994 geo metro & i'm replacing the timming belt but i ran across a problem. the cam shaft pully has two marks on it (1) mark has 60a & the other mark has 80c. so how do i aline the cam...
thats why you line everything up BEFORE taking the belt off. Usually when the timing marks are "ON" the dowel pin or key for the cam will be at the 12 o clock position. Also if you have the valve cover off, both cam lobes for number one cylinder will be pointing down.and both rocker arms loose. it would be a good idea to adjust the valves also.
Aug 31, 2010 | 1994 Geo Metro
Timing belt replacement
camshaft timing mark at 12 o"clock, align cam shaft timing mark to ( v ) cut on top of back timing cover, crank shaft gear align 12 o'clock key way up, there will be a mark on the outer edge of gear, on housing at 12 o'clock there will be the timing mark align that mark to crank gear , install belt and your done.Good luck.
Dec 27, 2009 | 1990 Geo Tracker
I need a diagram of engine timing marks for a 1.6 litre engine
1996 Geo Truck Tracker 2WD 1.6L MFI SOHC 4cyl
Fig.: Before installing the timing belt, position the camshaft sprocket (1) so that the timing mark on the sprocket (2) is aligned with the notch (3) on the inside timing belt cover (4) ...
Fig.: ...and ensure that the crankshaft sprocket (1) timing mark (2) is aligned with the mark on the oil pump (3)
For more details, can register in (free).
I hope help you with this (remember rated this help) Good luck.
Oct 15, 2009 | 1996 Geo Tracker 2 Door
Replaced timing belt on 1.0 Geo metro
you must take valve cover off and put the cam on it mark and with a wrench lock cam in place it would be help full if you have an a sis tent to hold cam in place while you put timing belt on good luck
Jul 19, 2009 | 1993 Geo Metro
1992 geo storm 1.6 timing marks
this is a pretty simple one here is a diagram. Good Luck and contact if you need more help. Thanks for using FIX YA
Jan 04, 2009 | 1992 Geo Storm
93 geo metro timing belt
niether those are timing refernces u use the dot good luck
timing mark = use the dot as dtc
timing referance marks
i just went through this for 2 weeks it spanked me
Oct 21, 2008 | 1993 Geo Metro
Geo metro timing diagram
woot i feel your pain i had the same problem. go to and go to thier vehicle repair.
enter your year make and model and find it. but please hear me on this one.. be carfule thier are like 2 timing references and one timing mark. USE THE DOT. pls i learned the hard way. lol use the dot on the cam sproket. good luck
Aug 18, 2008 | 1993 Geo Metro
Microsoft Office Professional 2007 Full Version for PC Logo
118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
