My monitor does not light up but just clicks - Computers & Internet
  • 94 Answers
If ur monitor is not coming up... check uplugging the monitor cable from the tower.... if u receive a msg on screen "No input signal" or "No VGA Signal" then Monitor is working fine... if not received monitor is not working properly.
if Monitor working... open the tower and remove memory (RAM) and switch on the pc... u should get beep codes.. if u dint get it.... Motherboard gone bad....else... try inserting RAM in other slot... even then its not lighting up...RAM problem or RAM solt problem..
Posted on Aug 20, 2008
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
Windows updated last night now monitor has blank screen w blinking power light plugged another monitor in works fine how do i fix this monitor
right click on your desktop and click properties(XP) or screen resolution(vista/Windows 7) on xp click on settings then see if you have two displays showing, if you have click on the one that is greyed out and click on extend my desktop onto this monitor and then click make this your main monitor click apply and click ok if your laptop screen shows your desktop its all good
Mar 11, 2011 | CTX EzBook FC3A300 Notebook
LT982s - 2 monitors 2 problems
With the SECOND (usually the RIGHT) mouse-button, click anywhere on your computer's "wallpaper".
Click Properties.
Click Desktop.
Click Identify and watch both screens.
One should display a large '1' and the other a large '2'.
Click 'Extend my Windows Desktop onto this screen".
Again, click Identify.
Apr 23, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
The monitor just stopped coming on
If you cannot see a power indicator light when you click the switch on... odds are you have a power supply problem.
If you click the switch on.. the indicator light come on and the screen will not light up - you have a blown fly-back coil.
The resolution ( if you are not technically inclined ) is to purchase a new monitor. The economics of monitors, especially ones that are not flat screens, says it is cheaper to replace them.
If this monitor is an LCD flat screen... you have a blown power supply and the resolution above applies.
Aug 13, 2009 | Hanns.G Corporation Computers & Internet
The moniter light will blink on and off randomly and the screen also turns on and off with the light. What can I do to fix this?
This is most likely due to power management settings for the monitor.
To address these settings follow the procedure below for your version of Windows.
To establish which version of Windows you have:
Press and hold the Windows Logo Key on your Keyboard + Press Pause Break Key and release.
To adjust power management settings in XP:
Click Start > Control Panel > Power Options > Adjust the drop-down menu for your Monitor.
To adjust power management settings for Vista:
Click Start > Control Panel > Classic View > Power Options > Click "Change Plan Settings under your current plan (the plan with a filled bullet) > Click "Advanced Settings" > Click Display > Click "Turn off display after"
Select 0 for none or choose the duration of inactivity to wait before Windows blanks your screen.
Apr 30, 2009 | Samsung SyncMaster 205BW LCD Monitor
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
Dell e193fp monitor
Have you made sure the laptop is outputting the the monitor? Does the monitor have dual inputs? if so check it is switched to the correct one. With the laptop turned on and connected, switch the monitor on and off.
good luck
fridge
May 17, 2008 | Dell E193FP 19" LCD Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Gateway EV910B Monitor
it is monitor fault and you will not be able to solve it is better to show the repair personnel.
Sep 22, 2007 | Gateway EV910B Monitor
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
