Question about Hotpoint First Edition FEW12 Front Load Washer
Filter query Hello.. My machine stopped half way through a cycle and won't empty. I can't find the filter? Any ideas?
  • Anonymous Nov 23, 2008
    Yes me too! HELP!!!
  • Hotpoint Master
  • 3,463 Answers
The filter is located inside trhe sump hose at the rear of the m/c.
You have to remove the hose to access it
Posted on Nov 26, 2008
Will run cycle but won't empty
dont know what machine type or model but it sounds like your filter is blocked or your pump clean out the filter first
Sep 26, 2012 | Washing Machines
Washing machine won't pump out to go into spin cycle is there a strainer that needs cleaning
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Aug 15, 2011 | Frigidaire Washing Machines
Defy automaid - just stopped spinning - all else is ok
Jul 19, 2011 | Washing Machines
Washing maching (automaid) just stopped spinning - washes but I hear the motor going through the moves - but it just does not spin. Worth getting fixed? How much will it cost? Thank you Auriel Abrahams
My bosch classixx 1400 express washing machine stops at spin cycle..
Jul 19, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Why does my creda washing machine stops when it gets to a rinse
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the next cycle with excess water in the drum.
Jul 05, 2011 | Washing Machines
Lg washing machine suddenly stop during washing
It would help to know at what stage the machine stops, however, lete me take a blind guess that it stops just before the spin cycle. If I'm guessing wrong, please tell us when the machine stops and if it displays an error code or any flashing lights (Please note WHICH lights flash and the number of times they flash, as this is an error code that will help pin the problem down).
If I'm right, then........
Jul 05, 2011 | LG Washing Machines
Water will not drain after first fill/runs then when it tries to start the drain cycle it just stops and does nothing
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the next cycle with excess water in the drum.
Jul 04, 2011 | Washing Machines
The washer will not drain. It goes through all the cycles, fills with water, washes, but when it gets to any of the spin cycles, it stops. The hose going to the drain is NOT clogged.
Jul 04, 2011 | Whirlpool LSR6232J Top Load Washer
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Hotpoint First Edition FEW12 Front Load Washer Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
