Question about Casio PRG-40T-7 Pathfinder
Battery replacement prg 40 model 2271
When attempting to replace the battery, a small spring fell out. Does anyone know which hole that spring goes back in?
  • jefH Aug 20, 2008
    the 2 gold colored springs are still there, but this spring is silver colored.
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Posted on Sep 11, 2008
When replacing the battery in my Citizen 8946-095604-ta a small spring fell out ,could you please tell me where it goes, thanks
it goes in a small hole in the back of the movement of the watch and connects to the back plate when replaced to operate the alarm.
Nov 28, 2012 | Casio G-Shock GW500A-1V Wrist Watch
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
I am changing the batteries in a Casio model 2271 watch. A small silver spring fell out during disassembly. Can you tell me where it goes back?
just bring your casio watch to casio service center, i'm sure they have what you are lookin for.
Jul 14, 2011 | Watches
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
I replaced all four batteries and i still have nothing .inside the watch it says to jumper the A C point with a twizers. what is the AC point and where.this s a casio 2271 2years old had factory batteries...
Casio battery changes are quite tricky.If you look closely at the watch module there is a place for the battery and a v-small depression usually circular on the silver module .There will be the letters AC in small writing.You need to touch the depression AC and the battery at the same time with a conductive tweezers.This shorts the module and re sets the watch.Make sure any seals go back in to protect from water/dust.
Regards
Aug 13, 2010 | Casio PRG-40T-7 Pathfinder
How do i change the batteries in my 2271
The safest option is to take it to a watch shop and ask them to change it for you.
While removing the back and replacing the battery,(assuming that is has a similar back to mine, which is the same make),is not too difficult, it can sometimes cause problems and since the charge for this is quite small, it is not worth taking any risk is getting it wrong. (Particularly difficult is making sure that the seal is properly made).
Considering the cost of you watch I would advise against doing it yourself.
Jan 25, 2010 | Casio PRG-40T-7 Pathfinder
Changed dead batteries on PAG-40. Still one dead watch
There is a very small sticker with very small red print just adjacent to the battery compartment. This little sticker states "once batteries are replaced, you need to touch AC with tweezers". I did it with metal tweezers and the watch display came to life. Good luck!
Jan 15, 2009 | Casio PRG-40T-7 Pathfinder
Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
Chabging the batterys on the prg 40
If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
Jul 01, 2008 | Casio PRG-40T-7 Pathfinder
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Casio PRG-40T-7 Pathfinder Logo
3,579 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
