Question about SanDisk Sansa e260 MP3 Player
Sansa MP3 I downloaded some songs, it said bad tracks, froze with a blue screen with alot of little things flickering on it, took out the battery it worked then froze i took out the battery again and now it the blue circle lights up with a black screen and nothing works i plug it in the computer and it charges but its not recognized
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it on the back of your computer...
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Posted on Aug 20, 2008
After deleted all the songs from my sansa e260 it's just froze
hook it back up to you computer the select start,mycomputer,e250, right click on icon and format device
i had the same problem with my sansa
Aug 01, 2009 | SanDisk Sansa e250 MP3 Player
Cannot get music on or off of MP3 player.
The 260 you can remove the screws on back cover and remove the battery and replace to reset, not sure on the 250, you might also want to go their website and download the latest firmware updates.
May 05, 2009 | SanDisk Sansa e250 MP3 Player
Bad track and Battery
Make sure the hold switch is not engaged.
Remove the songs from the player and then reload them. If they are froma subscription service, make sure they do not have fixed-term licenses on them. Right-click song --> Properties --> digital rights or media usage rights
Use Windows Media Player to view the songs that are stored on your mp3 player - best to view them in the "Sync" tab. Find the song that you want to delete, right-click the song, and select Delete (or left-click and press Delete on your keyboard). Voila!
-Tha Mp3 Doctor
Dec 22, 2008 | SanDisk Sansa e250 MP3 Player
My mp3 says "bad track" alot and freezes for about a day! help
The songs are in the wrong format. this player will not play iTunes, for instance.
Sansa Fuze supports MP3, WMA, secure WMA, Audible (AA), audiobooks and podcasts in
WMA and MP3 file formats.
Nov 02, 2008 | SanDisk Sansa m240 MP3 Player
Sansa disk e 260
I had the same problem with mine freezing. It happened when I kept pressing the back track button (on left side) to go back to an earlier song. It then froze in the middle of a song, couldn't hear the song, the time of the song was frozen, etc., and the unit stayed lit, despite pressing all the buttons. I tried holding down power but nothing happened. I read another person's post that you need to hold it down 15-30 seconds. I did this and it worked, you just have to hold it down until it shuts down, which was about 15 seconds as suggested, could be longer for others.
For me, next time I wont keep clicking the tracks repeatedly, I'll simply go out of the song and back to the song I want through the menu.
Thank you for the good posts. Glad I didn't have to mess with the battery like others....
May 14, 2008 | SanDisk Sansa e260 MP3 Player
"bad tracks"
The same thing happens with me, the only help I can give is that all of my songs which do not work are .wav files.
May 14, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Frozen in song.
The sansa e260 seems to have a hell of alot of faults. If SanDisk brings out a firmware upgrade definately take it, also I would strongly suggest that you write a letter to ScanDisk letting them know the grief it has caused you. I have an e260 and it has not had any problems so far, so I guess theres a little give or take sorta thing happening here.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
Bad Track
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
My sansa keepz bringing up songs as bad tracks or unknowns then doesnt play them
i'm having this problem too. what i think is happening is you took the song off the player. However, the it is not completly off of the player. i.e. song info still on their. song name, artist, album ect. i just took everything off of my player. it says 1/467 songs on their but all say bad track. thats the problem now about that solution, i'm looking into it. but ya if you have any problems. hit me up at headshot347@gmail.com or MXRIDER007R on aim.
May 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
