Network Terminals
Problem for Network Terminals
Generic problem for all Network Terminals
Wireless 802.1 Ig network/Wap
By billyb24_7 on Aug 20, 2008
I'm currently studying Comptia A+ N+, there are several Question I would like to ask.
I have read over and over my text books but toknow avail, Could you please help?
Question 7: You want to implement a wireless 802.1 Ig network that will be used throughout your building. The distance from one side of the building to the other is 300 meters. You install a WAP in the middle of the building to provide access to all clients. What is the problem with this configuration? What should you do to resolve the problem?
Question 10: You are installing a hub at a small remote office which has no IT staff. Which hub feature would you consider for this application?
Comments:
Aug 20, 2008
- Thanks ever so much Ref Question 10 what hub feature woul I use ? Passive, Active or Intelligent.
Assistance Gratefully appreciated,
Billy
Best Solution
posted on Aug 20, 2008
Very Helpful)
Ekse
Rank: Guru
Rating: 88%, 4785 votes
In the question 7 of your homework? hehe
the problem is with the signal, this would work if the whole 300m was visible you could look from the other end to the other. It would work in a hall or a open space. but as there are walls in between the range doesn't extend as far. Personally I would Use 3 wireless accesspoints to cover the whole building, if there are many stores. I might need to add additional accesspoints to cover the whole building.
Question 10
I would personally choose a remotely configureable switch / hub. so if a problem came up I could connect to it from my workdesk.
Comments:
Aug 20, 2008
- I mean if there are many floors in the building. Stores, well you know what I mean, not shops.
Aug 20, 2008
- Intelligent, it has the remote control features.(network management, etc etc)
I would say it is the best choice to a remote office with no it staff.
Intelligent Hubs:
Intelligent hubs add some more features to that provided by the active hubs. An intelligent hub provides all the features of a passive and an active hub; it also provides some features, which help in managing the network resources effectively and efficiently. Intelligent hubs help in improving the performance of the network/LAN that you are using. As an active hub helps in finding out where the problem persists, an intelligent hub itself finds out the problem in the network, diagnoses it and tries to rectify it without letting the problem hamper the performance of the network. Intelligent hubs provides feature that helps in determining the exact cause and exact place of the fault, this saves lot of time and energy which otherwise would have been required for finding out the exact place of fault and identifying the solution for it. Another feature of intelligent hub is that they can decide which packet goes in which output line, this helps in controlling and minimizing data traffic in the network, which results in improved performance of the network/LAN.
Intelligent hubs also help in managing the data communication within the network, it recognizes the slower devices automatically and helps them to transmit the data with their own speed, and during this time the hub manages the traffic within the network effectively. This feature also improves the performance of the network manifolds. An intelligent hub also adopts the changes in the network very easily and it also supports different technologies without need of changing anything in configuration.
Source:
http://www.buzzle.com/editorials/2-6-2005-65413.asp
Aug 20, 2008
- as these are just school questions Id say intelligent is the best choice but in real life it would debend, obviously if the remote office has only 1-2 people it wouldn't be smart to invest in a intelligent hub, a passive or active one might do just fine.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Network Terminals
Questions and Unsolved Problems for Network Terminals
Answer
I have a WYSE S90 that is rebooting the Guest OS (Windows XDe) every 16 minutes. It looks like there... (More)
Answer
HP thin client not shairing printer properly
Answer
Problem loading page, ssl protocol disabled can you fix this I cannot get my emails on any web and I... (More)
Answer
printer is installed on thin client now from other thin client we want print to printer in network.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Network Terminals Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
