LG 24 in. LDF 7811 Built-in Dishwasher Logo
Posted on Jun 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Displaying code IE - LG 24 in. LDF 7811 Built-in Dishwasher
Anonymous
Level 3:
Guru:
  • Master 500 Answers
  • Posted on Jun 16, 2011
Anonymous
Master
Level 3:
Guru:
Answers
500
Questions
Helped
203009
Points
1335
Hi jakkirker,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Frigidaire Affinity. Why is it displaying error code E-9F?
https://www.google.com/search?q=Frigidaire+Affinity.+Why+is+it+displaying+error+code+E-9F%3F&oq=Frigidaire+Affinity.+Why+is+it+displaying+error+code+E-9F%3F&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
1helpful
Where is the transmission warning light in the display
In most vehicle, Transmission warning light incorporated in Check Engine light (ie, when you pull check engine light codes, transmission trouble code will be among it, if there were any), other case, its in your PRNDL indicator light (ie. PRNDL light will blink when transmission has problem), and in another case, you need to have a special scaner that capable of pulling transmission trouble code. I hope it helps :)
IE error code
Water inlet error - washing machine failed to fill
The fault code is displayed, if the washing machine does not detect any incoming water.
·Check wiring to water inlet valve
·Check water valve
·Check drain pump
·Check pressure switch
Check PCB
Washer displays IE. What does that mean?
is this an Lg washer ie error code is an water inlet error either low water pressure , kinked fill hoses or bad water valve ....
8helpful
2answers
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
11helpful
2answers
IE error code
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
3helpful
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
2helpful
Toshiba DKT2020-SD 20 Button Display Speaker Digital Telephone
To change the time, go to extension 10, while keeping the handset on hook, push intercom, then dial # 6 5 2, enter the new time ie. 102510 (hour, min, seconds), then push the redial key to save. That should do it. to set the day use the intercom # 653 code (1=Sun, 2=Mon, ect). To change the date use the intercom # 651 code (ie. 080510). If that does not do it, you may have a different model key service unit, and you will need to notate which system your using.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
