Question about Fisher and Paykel Washing Machines
Fisher and Paykel Intuitive has Error Code 43
I had the same problem, code 43 is an out of balance switch problem, i found mine was just sticky, if you pull it out (under the electronic control unit, under the top panel) you may be able to find out if its stuck or if it needs a new one, you could possibly find one from another model. hope this helps
Posted on Dec 26, 2008
  • Kevin Mcgill Jul 05, 2011
    Very helpful just undo the 2 screws at the back of the control panel at the top of machine then undo 1 screw in the centre that holds the control board pull it back MAKE SURE POWER IS OFF and you will see the switch on the right side under power board 1 you can take the 2 wires off and somehow join them together for a temp fix or permanent but you will have no out of balance and it is only low voltage so you can join wires or stick a little piece of steel into both of them so they touch each other until you get a new one it is a limit switch when buying I joined wires and is working well 6 months on.
  • 76 Answers
SOURCE: HELP!! fisher and paykel intuitive clothes washer: error code 36
schmotty, An error code "36" means Water leak fault: The Motor Control Module has needed to top up the water level more than 4 times during agitate. This is excessive, as normally only one or two top ups are required to replace the air that has escaped from a full load during agitate. The most likely cause is that the machine is siphoning. The other alternative is that the machine has developed a leak.Thats what you have to do: Primary Source: Pump System. Action 1) Check the height of the drain hose outlet. Minimum 33.46in / 850mm, maximum 47.24in / 1200mm. 2) Check that the hose guide is fitted and check that the hose does not protrude more than .78in / 20mm beyond the guide. Secondary Source: Mechanical. Action: 1) Check the pressure tube connections on the outer basket and Motor Control Module. 2) Check that the drive shaft seal and the pump housing seal have not developed a leak. Tertiary Source: Motor Control Module. Action: Replace Motor Control Module. Gendos...post it
Posted on Jan 02, 2007
Tech007
  • 63 Answers
SOURCE: fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Posted on Jun 09, 2008
Tech007
  • 63 Answers
  • 4 Answers
SOURCE: Whats a code 43 on
That's an 'out of balance' switch problem. Typically caused by a crook microswitch that lives under the main processor housing. Can replace with a generic switch from Jaycar or similar if needed.
Posted on Feb 26, 2011
what is a code 43 please what is wrong with the machine ty code 43 is displayed on the screen andi have done nothing to try to resolve the problem i just got straight on to your website.. please solve my problem... tq
Posted on Dec 18, 2011
43 error fisher paykel
Out of Balance Switch Fault Fault code #43
The out of balance switch is permanently activated or the harness to it is disconnected.
Nov 17, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 43 on intuitive top loader
hello click this link for error code 43 this is an out of balace error and this link will tell how to fix as well http://applianceguru.com/forum2/3397.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 43
Hi just read your posting.Error code 43 is called OUT OF BALANCE SWITCH ERROR.This means either your switch is faulty or your your control module is faulty.95 % of the time it is your switch which is located under the control module which is under the top panel.If you want I can guide you step by step in the replacement of this switch.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine stopped filling up and an error 43 or 43 came up on screen
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washer what is a code 43 please
code for out of balance oob switch probably needs replacing if load wasn't off to one side.
Jun 20, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Jun 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,118 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
