Question about Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive
WD My Book Essential 320GB external storage device
After a year of working fine, suddenly the device is not showing up on my computer at all. I have tried everything I can think of from changing cables, power sources, software from WD site (could not get actual software for the case). The device seems to be working, the light comes on when plugged in to the computer although it does pulsate. Help!!
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
I have bought a WD My Book Essential and I want to install it. My OPS is Windows 7. Drivers software installation (the PC saids OK) " Yours device is ready for use" USB mass storage device...
You have to expand the "Disk Drives" device manager entry to see your MyBook Essential external drive.
These drives are formatted at the factory, and you should also be able to see it in Windows Explorer. It will automatically be assigned an unused drive letter, and accessible immediately.
Oct 08, 2017 | Dell Computers & Internet
I have a western digital essential 1 TB external hard drive.I have windows vista and it has usually worked fine until one day i tried to plug it into a different computer that has window's 7, but it...
HI, RULE #1 IS "ALWAYS" ATTACH/PLUGIN WHILE PC IS SHUT-DOWN. NEVER CONNECT/DISCONNECT WHILE RUNNING. GO TO CONTROL PANEL, DEVICE MANAGER, SCROLL TO BOTTOM, CLICK + WD DRIVE MANAGEMENT DEVICES, SEE IF WD SES DEVICES IS THERE IF IT IS, DOUBLE CLICK IT. A WINDOW SHOULD POP-UP SEE IF IT SAY'S THIS DEVICE IS WORKING PROPERLY. IF NO DRIVERS ARE INSTALLED, CLICK UPDATE DRIVER. IF THAT DOES NOT WORK, GO TO CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE, CLICK DISK MANAGEMENT, MAXIMIZE PAGE, SEE IF MY BOOK IS THERE. IF IT IS, RIGHT CLICK, THEN MARK PARTITION AS ACTIVE...........I HOPE THIS HELPS..........JEFFXC
Jan 25, 2011 | Western Digital My Book Essential 1TB...
My hard drive will not show up on my laptop when I plug it into the USB port. My USB ports work fine on the laptop because other devices show up. My hard drive was working before, but now it won't show up...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 11, 2010 | Western Digital My Book Essential 1TB...
My memory gauge keeps blinking and the drive won't show up on my computer
* the USB cable
* the power-adapter
Nov 17, 2010 | Western Digital My Book Essential 320GB...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
WD my book essential not working on windows
pls i really appreciated if you help me to find a free driver for my wester digital external hard drive 500 gb pls send it to my email how do i get a free drive .... my email: deejhay17@yahoo.com
Jan 22, 2010 | Western Digital My Book Essential 1TB...
Western digital my book essential edition 320gb no installer
try this go to comp, right click go to properties,got to devives in the top left hand corner open this go down the the bottom click on usb controllers then scan for new hardware.
Jul 31, 2009 | Western Digital My Book Essential Edition...
WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Apr 29, 2009 | Western Digital Passport 320GB External...
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Jul 13, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive Logo
199 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
