Question about Canon PIXMA MP130 All-In-One InkJet Printer
MP130 saying cartridge jammed press ok. what do I do?
My MP130 is saying cartridge jammed press ok. what do I do?
I've suffered this fault a couple of times now (coinciding (?) with an empty black tank) . I found this solution on the internet and after a bit of messing around (and several attempts) it does appear to work...
Open the cover as if you would change the cartridge. Then press the little black button (left side, under the cover). Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will go through the motions of copying in black. Wait until it stops again. Then close the cover and press the black button again. Now it should copy… and print, and so on.
This is very common and an obvious F/W bug with the PIXMA printers...Canon needs to somehow address this as there are a growing number of dissatisfied customers
Posted on Aug 20, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm...i'd turn off the power first, then let it reset that way..
My canon pixma mp30 keeps saying cartridge jammed pls can you tell me if i can fix it cos it wont print. thanks
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
Dec 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Printer states cartridge Jammed, pressing OK does not fix problem Cannon Pixma MP130
Remove and re-insert the cartridge to see whether the fault will go.
Sep 03, 2009 | Office Equipment & Supplies
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge jammed
This was given to me to fix error 5100, and worked:
Press Menu, then Scan, Copy, Scan toenter Service Mode
Press the + button until you arrive atNVRAM ACCESS, press OK
Use the + or - buttons to reach ABS-MLEVEL, press OK
Set the level on zero and press OK
Use +/- to reach ABS-P, press OK
Set this level to zero and press OK
Press STOP to exit the menu
Switch off and restart the printer.
Mar 18, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge Jam
try to put out the cartridge casste and put it back then clean the nozzles
Feb 12, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
794 people viewed this question
old marine
old marine
