Question about HP DesignJet 450c InkJet Printer
Plotter the lights aren't flashing and when i push canacel oly the media light is on .can you give me a solution as soon as possible plesa. thank you for your help
    Problem Solver:
  • 7 Answers
It may one of the following, try these and see if you have any changes. If it happens while loading media the sheet you loaded may be misaligned or it may be an an invalid size.
The media lever may be lowered if so raise the lever.
Or the cover is open when the printer is initializing. Lower the cover and power back on.
Hope it is one of these and not something serious.
Posted on Aug 28, 2008
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
I have a Fishman pre-amp mod MKAB Acoustic Base Optimized in a Michael Kelly Dragonfly 5FL TBK.. as soon as the plug is pushed in the jack, the battery lite on the amp flashes for an instant , then goes...
Most acoustic/electric pre-amp's red light comes on when the battery is low & ready to die. The red light flashes when you put the jack in because the battery light takes a fraction of a second to proccess. If the red light flashes off & on when you push on the pre-amp, it is probably because you are causing the battery connector to short or disconnect giving the pre-amp low voltage so the red light comnes on.
Nov 06, 2010 | Fishman Audio Players & Recorders
Problem with plotter
That sounds like a carrage movment problem. When you load paper the carrage moves from the RHS very quickly. If your carrage is not properly lubricated you will get that fault. Before going further you must switch off and open the cover. Look along the length of the belt (just below on the aluminum) if there ere lots of reddish pieces and a dust like substance it means that your carrage belt will need replacing. If the belt is ok, then move the head to the middle of the machine by hand and apply a drop of thin oil (sewing machine) to either side of the carrage on the bar. Move the head slowly left and right to lubricate the bar. It then should be ok.
Good luck
Dave
Jun 02, 2009 | HP DesignJet 450c InkJet Printer
My sony mp3 mp4 mp5 game slide panel pmp stopped ! when i push power key oly shows ''loading .....'' not usb activation! how can i format it with combination of keys or how can i give firmware to this?
i pluged the usb in to transfer some files and mp4 turned off it self, and now it wont turn on. i tried reseting it but it stil wont work. When i put it on charge the power light shows that its charging but wont ******* turn on.
Apr 24, 2009 | Audio Players & Recorders
HP designjet 430 E Plotter
The reason it could be the main board is that it tells the front panel lights what to do. This seems like a logical problem the printer is having, usually things freeze when internal memory is bad. Surely have the main board replaced. There is a part of the internal programming that it cant get past. Compare it with trying to read a sector of a cd-rom that is scratched.
Oct 21, 2008 | HP DesignJet 450c InkJet Printer
Are the lights flashing? If they are flashing it is a system error, if they are on steady it is a recoverable error. When you push cancel is the media light the only one or is align media or ready on as well?
Aug 11, 2008 | HP DesignJet 450c InkJet Printer
ERROR LIGHTS
Is your ready light on as well? If so this may indicate that the "mark encoder" is not detected.The mark encoder is the white plastic piece on the left end of the large black roller that the paper feeds around.If the encoder is very dirty,then cleaning may help.If not, carriage usually has to be replacved, I have heard of some that paint over the mark encoder with white out before replacing the carriage. Don't think I would try it but....Hope this helps.
Jul 24, 2008 | HP DesignJet 450c InkJet Printer
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
HP design jet 450C inkjet Media Error`
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Jan 09, 2008 | HP DesignJet 450c InkJet Printer
Can I use my old (non- FL40) flash with my C2100??
Of course there are some who claim that trigger voltage is unimportant. I tend to believe them ,as there is no documented evidence from anyone that their camera has been harmed by using non proprietary flashes. Some posters are using older flashes with success and no harmful results. Do you have the nerve to try it? if so let us know.
Sep 11, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
HP DesignJet 450c InkJet Printer Logo
54 people viewed this question
Ben Johnson
