Question about Teac Audio Players & Recorders
How do I set the presets on the Teac T-R450 tuner/amplifier?
  • 44 Answers
You'll want to turn on "tuning mode" by pressing the button. Push the number preset you want to store it in, tune it to the station you want to save, then press and hold down the "memory set" button for awhile. The display should flash or some other indication that it is stored. When this is all done test the preset button by pushing it. If it stayed on the same station, it was successful.
I hope this helps.
Posted on Aug 20, 2008
Teac problem
Bulb is probably burnt out.
Jul 25, 2014 | Teac A-H300 Amplifier
How do i change tuner channels
This is a power amp, change the channels on the tuner:
May 26, 2014 | Teac A-H500 Amplifier
Tuner does not work on my Tuner Amplifier
Check to see if the antenna is loose. Most amplifiers will mute the output if they don't detect a strong radio signal.
Jul 26, 2013 | Televison & Video
Can you connect speakers directly to teac t-h300 tuner
No the outputs need to be connected to an amplifier.
LPG
Sep 11, 2012 | Teac T-H300 2 Channels Tuner
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Nov 03, 2010 | Teac EX-CD3 CD Shelf System
Teac amplifier av-h500
rush it to a service centre as something has blown on it it is protecting the speakers from damage
Jun 14, 2010 | Teac A-H500 Amplifier
Constant humming regardless of Tuner or Cd or Aux settings. Pops when I shut if off too.
This could be several Things. if your getting a humming:- Possible loose wire/Connection at plug/socket outlet et,c. Pre-Amp/Amplifier problem on PCB ( printed-Circuit-Board of actual device ) fets et,c.
The pop at shutdown, would most likely be Amplifier Problems.
Recommendations:- return the base-item to an electrical goods repair Specialists, For an estimation/Quotation.
Mike @ compurepair.
Nov 04, 2009 | Teac EX-M5 Shelf System
CR-H100 CD/Tuner/ Amplifier. New about 5 years ago. Tuner won't retain presets. Despite following manual's instructions on both auto and manual tuning, the preferred programme settings are almost always...
These resceivers have a bulit-in device to retain some electricity to feed backup memory. It can be a battery or a capacitor and I think they have reached their time to be replaced.
Nov 21, 2008 | Teac Audio Players & Recorders
154 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
